  • Replies 134
Posted Images
I really like that location gus :D Nice pics too
Just one quick suggestion - i reckon a tad less exposure on these would have been better.
What settings did you shoot it with? Exif data isnt intact :D
Camera Make: SONY
Camera Model: DSLR-A200
Image Date: 2008:11:11 21:55:55
Flash Used: No
Focal Length: 35.0mm (35mm equivalent: 52mm)
Exposure Time: 15.000 s
Aperture: f/5.6
ISO equiv: 100
Exposure Bias: 1.00
White Balance: Auto
Metering Mode: Spot
Exposure: aperture priority (semi-auto)
exif shows for me
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
