  • Replies 60
Posted Images
Um, stagea is only 1680kg's, and not over 1700kgs as previously stated.
I used to own a stagea, and I have spent a bit of time in Mitch's as both passenger and driver. Now *dons flamesuit* I have to say that I would prefer the leggy myself. The thing is, the stagea is NOT a sports car and never will be - its a luxo barge. The leggy FEELS much lighter when you are driving it, it has a bucket load more kick from a standing start and the triptronic is light years ahead of the stagea IMO. I also dont believe that you can point at them and say they have crap gearboxes. I think, also as previously stated, that it is more of a maintenance issue than a reliability issue, but no matter what car it is, ALL imports share the same risks in this area.
A S2 ("facelift" model) S type would be my pick - but def try and get the hi-vis dash at a minimum. They are teh shizz.
RS4 is kinda in a slightly different price range.. lol..
the other car that wagon lovers might want to consider..
Caldina
here's a few someone prepared earlier
Too Bad you cant get the new shape for that price
190kw standard.
lighter than the others in this thread.
toyota over engineering.
gen 3 3SGTE motor
Edited by GTST
yeh not a big fan of the caldina either...the shape doesn't look right...reminds me of a extended toyota starlet...the newer one is o.k but then i think i would want a m35 instead.
see also carmen imports here in brissy. he has two of them that the ENTIRE MMCS system works :P ( I know this because I did them.)
kristian,
you speak my language.
NM35->EC5W- WGNC34 ->ST246
Caldina
190kw standard.
gen 3 3SGTE motor
Thats feral
M35 > EC5W > WGNC34 > ST215W
my lineup is a bit different...
EC5W > WGNC34 Series 1 > M35 > WGNC34 Series 2 > ST215W
the S1 stag's can look awesome with a good set of rims and lowered.. the S2's are just ugly all the time. :)
The more i see the more i like of these things haha.
Jake get a VR4 :)
lolz man i'm considering if i sell the r32...if not a legnum i will buy a galant...i like the practicality of it. heaps of space, power and rare. maybe if i can find a good priced manual i might get one.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
