after a lot of talking and reading i have changed my mind from gtss turbos to Garrett 2860R-5.....
i will have all the surport mods sorted! its a built motor to....
i have been told they will come with gaskits ect but what needs to be modified to fit them just the oil return line? do i need a oil restrictor in the line going to the turbos?
any advice would be great!!!!
this is for a r32 gtr also
thanks in advance steve
https://www.sau.com.au/forums/topic/243305-garrett-2860r-5/
ported head matched manifolds
jun guilds stano vavles
stock cams
stock cam gears and springs
baffled sump oil restrictors in the block cam cover plates
jun collar and oil pump
acl race bears mains and big ends
rev rods
cp pistions
1.3mm metal head gaskit
metal inlet manifold gaskits
pfc
stock cooler
stock inj stock fuel pump
stock air flow meters
stock dump pipes
front pipes 3 inch cat 3inch exhuast and cannon
stock turbos
os giken twin plate clutch
eboost 2 set to 13psi
262rwkw 351hp
i also have sard 720cc inj now and a sard pump and greedy hard pipe kit is on the way.... i will also be getting nismo afm
https://www.sau.com.au/forums/topic/243305-garrett-2860r-5/#findComment-4240593
so did you just use the stock gaskits? new ones of course.....
pritty much.. they came with my tomei gasket kit as i did head gasket at the same time aswell as a couple other things
nice list of parts, you'll need afm's aswell if your goin the -5's, either nismo's or Z32's
https://www.sau.com.au/forums/topic/243305-garrett-2860r-5/#findComment-4240622
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
