I told John Keen at hi Tech Dyno that i want at least 200kw at the wheels in my R32 GTR with just a cat back exhaust and he said that they should come standard with between 197-212kw at the wheels.
Should i get 200kw at the wheels with a cat back exhaust and how much boost???
https://www.sau.com.au/forums/topic/243311-stock-r32-gtr-power/
get a vi-pic + 3 inch turbo back exhaust + i bar boost and you should get about 255 kw @ the rears
thats about what im getting
and pray you ceramic turbos dont fall apart
Edited by gazza750
Im getting 240KW on 10psi, HKS piping, Z32AFM + 3.5" exhaust
Fark thats pretty good!
10psi = +0.7 Bar (Approx), which is stock boost. You for real or you gota happy dyno LOL! :banana:
Was at a Dyno Day and saw a stock R32 GTR dyno and hit 155kW at all 4's
Then when doing some research, I read it was about 185kW at all 4's, so all dynos differ.
dynoed 1 a few weeks back..
220rwkw completely standard
WOW they only came from the factory brand new with 206KW @ the flywheel
so i dont understand how you get a drivetrain gain when its always a drivetrain loss
Thats the Japanese Manufacturers Gentlemans agreed value that all cars will not exceed.
Its been covered on the forums a number of times now.
Cause if the GTR only has 206kw then there is something seriously wrong with both my V8's that make more than that but dont perform as well.
10psi = +0.7 Bar (Approx), which is stock boost. You for real or you gota happy dyno LOL! :rofl:
Yeah i guess all dynos will differ between results but for an odd 100kw is a bit extreme, ill post the dyno sheet up for a look see its approx 10-11psi making 238.4 (i think) at all four, this tune was done at Race Solutions in Sydney after putting a new engine in the car with the odd modification as said. Hmmm ill have to check it out tonight then :laugh:
Yeah i guess all dynos will differ between results but for an odd 100kw is a bit extreme, ill post the dyno sheet up for a look see its approx 10-11psi making 238.4 (i think) at all four, this tune was done at Race Solutions in Sydney after putting a new engine in the car with the odd modification as said. Hmmm ill have to check it out tonight then :rofl:
At all 4 wheels even... I was gonna say was it at the rear wheels.
LOL! All good then.
What engine did you put in? Like a new RB26 or N1?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
