I told John Keen at hi Tech Dyno that i want at least 200kw at the wheels in my R32 GTR with just a cat back exhaust and he said that they should come standard with between 197-212kw at the wheels.
Should i get 200kw at the wheels with a cat back exhaust and how much boost???
https://www.sau.com.au/forums/topic/243311-stock-r32-gtr-power/
get a vi-pic + 3 inch turbo back exhaust + i bar boost and you should get about 255 kw @ the rears
thats about what im getting
and pray you ceramic turbos dont fall apart
Edited by gazza750
Im getting 240KW on 10psi, HKS piping, Z32AFM + 3.5" exhaust
Fark thats pretty good!
10psi = +0.7 Bar (Approx), which is stock boost. You for real or you gota happy dyno LOL! :banana:
Was at a Dyno Day and saw a stock R32 GTR dyno and hit 155kW at all 4's
Then when doing some research, I read it was about 185kW at all 4's, so all dynos differ.
dynoed 1 a few weeks back..
220rwkw completely standard
WOW they only came from the factory brand new with 206KW @ the flywheel
so i dont understand how you get a drivetrain gain when its always a drivetrain loss
Thats the Japanese Manufacturers Gentlemans agreed value that all cars will not exceed.
Its been covered on the forums a number of times now.
Cause if the GTR only has 206kw then there is something seriously wrong with both my V8's that make more than that but dont perform as well.
10psi = +0.7 Bar (Approx), which is stock boost. You for real or you gota happy dyno LOL! :rofl:
Yeah i guess all dynos will differ between results but for an odd 100kw is a bit extreme, ill post the dyno sheet up for a look see its approx 10-11psi making 238.4 (i think) at all four, this tune was done at Race Solutions in Sydney after putting a new engine in the car with the odd modification as said. Hmmm ill have to check it out tonight then :laugh:
Yeah i guess all dynos will differ between results but for an odd 100kw is a bit extreme, ill post the dyno sheet up for a look see its approx 10-11psi making 238.4 (i think) at all four, this tune was done at Race Solutions in Sydney after putting a new engine in the car with the odd modification as said. Hmmm ill have to check it out tonight then :rofl:
At all 4 wheels even... I was gonna say was it at the rear wheels.
LOL! All good then.
What engine did you put in? Like a new RB26 or N1?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
