  • Replies 327
Man I just get back from Brisbane for a holiday and this is what you guys do to me? Seriously I bet half of those post were just so I would have to go through them and check the roster hahahah anyway here is the new list guys
Attendance List (As of 27/11/08) REV 1.1
Order By Car
Confirmed
Leanbac - AP - R32 4Door << I GOT IT THIS TIME GUYS!
Lil_Lucky - Chad - R32 GTS-T
Rekin - Patrick - R32 GTS-T
K1ngtr - Aquilino - R32 GTR
(00)Skyline(00) - Jamie - R32 GTR
Basti - Niroj - R33 GTS-T Auto
Krzysiu - Kris - R33 GTS-T SII
JamesK - James - 1995 R33 GTS-T
nismo_GTS - Antony - 1996 R33 GTS-T
ITZTRU - Justin - R34
B3za - Bez - R34 4Door GT
llama_au - Juliette - N15/R34
RBPOWA - TJ - Steaga S2
Nismo_Racer - - Alfa Romeo
Jezza_Boii - Jeremey - MR2
GTTR34 - -
Maybe
[WLDCRD] - Glenn - R32 GT-R
tin-pain - Tin - R32
D_33vl_1 - Brad - R33
~R33AzzA~ - Aaron - R33
Dezz - Michael - 1998 R33
Rchoo - Wayne - R33 GTS-T (Hope all is well Rchoo)
Gazal - Alan - R33 GTS-T
DogKnight - DK - R33 S2
dreamr33 - Adztro boy - 1997 R33 GTS-T
DRFT31 - - R34 GT-T
Sandeep - 1990 300ZX NA
Psyche out
Dngrus - Ferah - R34 GTT (Something Important...apparently)
eMsta - Matt - Jazz/R33 (Who's surprised?)
MP_R33 - Ross - 1998 R33 GTS-T MP (Work)
GTRBOS - Tony - R32 GTR (Car at Racepace)
Htial - - R33 GTS-T (Car troubles)
SIF not writing my name down for the 2nd time
so if it does rain is it canceled?
Hell no man!
Cya there.
NEVER! It just means a free car wash for everyone. :blink:
See you guys there tonight.
Wow man, you actually coming out tonight... Good to see ya again.
You bringing the Rollar or the 4 Door GTS-T?
Good Work JamesK!!! + Mr. Nur (Tim GTR) will hopefully make it too. ATM he is at a strawberry farm eating ice cream = Nice! LOL!!!
I’ll bring the Pullstart tonight. Ignore it misfiring and stalling, it’ll sound like pooh. But I just want to drive it. Plus you’ve all met the Skyline anyway so I’ll give it a rest.
hey tj what time r u gonna be at the car wash? might join you
Who me..?
I will meet you ppl in St. Kilda as Im in Richmond already.
Wat time you think you all be down there by? 8ish?
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
