  • Replies 327
Man I just get back from Brisbane for a holiday and this is what you guys do to me? Seriously I bet half of those post were just so I would have to go through them and check the roster hahahah anyway here is the new list guys
Attendance List (As of 27/11/08) REV 1.1
Order By Car
Confirmed
Leanbac - AP - R32 4Door << I GOT IT THIS TIME GUYS!
Lil_Lucky - Chad - R32 GTS-T
Rekin - Patrick - R32 GTS-T
K1ngtr - Aquilino - R32 GTR
(00)Skyline(00) - Jamie - R32 GTR
Basti - Niroj - R33 GTS-T Auto
Krzysiu - Kris - R33 GTS-T SII
JamesK - James - 1995 R33 GTS-T
nismo_GTS - Antony - 1996 R33 GTS-T
ITZTRU - Justin - R34
B3za - Bez - R34 4Door GT
llama_au - Juliette - N15/R34
RBPOWA - TJ - Steaga S2
Nismo_Racer - - Alfa Romeo
Jezza_Boii - Jeremey - MR2
GTTR34 - -
Maybe
[WLDCRD] - Glenn - R32 GT-R
tin-pain - Tin - R32
D_33vl_1 - Brad - R33
~R33AzzA~ - Aaron - R33
Dezz - Michael - 1998 R33
Rchoo - Wayne - R33 GTS-T (Hope all is well Rchoo)
Gazal - Alan - R33 GTS-T
DogKnight - DK - R33 S2
dreamr33 - Adztro boy - 1997 R33 GTS-T
DRFT31 - - R34 GT-T
Sandeep - 1990 300ZX NA
Psyche out
Dngrus - Ferah - R34 GTT (Something Important...apparently)
eMsta - Matt - Jazz/R33 (Who's surprised?)
MP_R33 - Ross - 1998 R33 GTS-T MP (Work)
GTRBOS - Tony - R32 GTR (Car at Racepace)
Htial - - R33 GTS-T (Car troubles)
SIF not writing my name down for the 2nd time
so if it does rain is it canceled?
Hell no man!
Cya there.
NEVER! It just means a free car wash for everyone. :blink:
See you guys there tonight.
Wow man, you actually coming out tonight... Good to see ya again.
You bringing the Rollar or the 4 Door GTS-T?
Good Work JamesK!!! + Mr. Nur (Tim GTR) will hopefully make it too. ATM he is at a strawberry farm eating ice cream = Nice! LOL!!!
I’ll bring the Pullstart tonight. Ignore it misfiring and stalling, it’ll sound like pooh. But I just want to drive it. Plus you’ve all met the Skyline anyway so I’ll give it a rest.
hey tj what time r u gonna be at the car wash? might join you
Who me..?
I will meet you ppl in St. Kilda as Im in Richmond already.
Wat time you think you all be down there by? 8ish?
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
