What to do..
19 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
i'll see how i go with this one man...might be cramming to get my assignments done lolz...but most likely will be there. bring ur crew also and hopefully some of my friends might come out.
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4241022
haaha last minute cramming FTW.
Yer some of the usuals will hopefully come down, hopefully some new faces aswell. We will see how it goes
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4241087
Gonna do anything or sit at the car wash like sick karnts?
Might come down to finally meet some of you :huh:
Well im up for a cruise i guess, comes down to what everyone else wants to do though.
Theres now a poll to decide what we do :P
Edited by MP_R33
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4243184
lets hope its good weather too...bloody skool been draining me hardcore..haven't gone out in a while...i'm 75% in. ey ross can steve get discounts at supercheap? if so how much cause i wanna get some gearbox oil from him.
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4247991
He could get discounts, although he no longer works there as of monday last week, he quit lol
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4248461
Just reminding everyone its this Sunday night (should be some nice weather)
If you haven't come down to one before, they're great for meeting new people and checking out all the other local cars.
Last one we had pulled quite a few cars around 15ish from memory, lets try make this one better.
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4252813
Is it sunday or saturday?? Up the top it says sunday... got an 18th on saturday
https://www.sau.com.au/forums/topic/243344-west-meet/#findComment-4256634
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
