hey lads,
Soon i will be putting a series 1 rb25 into my cefiro with the following mods attached.
intercooler, air filter, 850cc high impedence injectors, 040 pump, fuel press reg, hks head gasket, arp bolts, spool rods, acl forged pistons, king bearings, ss high mount, gt3082r (3040) with a .62 rear, profec b spec 2, 40mm ex gate.
Now i am unsure on what computer to go with. this may have been a topic already covered on here and i did a bit of a search but with not satisfactory results. I want to avoid using an air flow meter and im happy to spend up to about 1500 for the computer. I have had people suggest the Autronic, hks fcon is, power fc, haltech. im sorta stumped and would love to get some advice from dudes who have been through this process. any help much appreciated.
Cheers guys.
https://www.sau.com.au/forums/topic/243449-what-computer-should-i-run/
any particular reason u prefer to run without an afm? otherwise id just say emanage ultimate or power fc ( although power fc u can run MAP), i luv my autronic but it probably will be over kill no need to spend that much.
ben...
can some one link me to this vipec and who sells/tunes them in bris gold coast?
Godzilla Motorsport is the dealer for Vi-PEC in Brisbane...contact Mark and he will look after you with both supply of computer, tuning and advice.
www.godzillamotorsport.com
Edited by DiRTgarage
who is a dealer/tuner for these in Melbourne?
JPC
here's a full list of dealers worldwide
http://www.vi-pec.com/page_files/dealer_list.htm#queensland
The HKS Fcon iS has optional MAP sensor capabilities. I think they are very competitive on price too compared to the likes of the TRUST Emanage and Haltech ECU's in this class.
Give Alex from GT Auto Garage in Brisbane a call. www.gtautogarage.com.au
Also, see here: http://www.skylinesaustralia.com/forums/Gt...60#entry4229460
Edited by Zensoku
depends on which tuner you go for
but for the $$ vi-pec or haltech seems very popular
both have antilag/launch control/boost control etc etc
haltech is more pricey though
but i think a power fc d-jetro (map sensor) will be around 2k these days?
(if they make it for your car)
my votes going to go for the wolf v500. but i upgraded from a power fc to one and it was the best thing i've done.
little bit over your price but well worth the cash.
what car?
what power level?
and what exactly was the big improvement?
:P
i got quoted $1400 from gt auto for the hks unit. the issue is not everyone can tune that ecu and i supose that is the same for a few of the options i am limiting myself to. i dont know im still torn on what to get.
I would say. Go and find a reputable tuner that you can and will trust with your car and feel they are the right shop for you. Speak with them and ask them what they would recommend as they are the ones tuning it. I got on here and asked similar questions and they all told me power FC. i went with a microtech as my tuner has told me it will work and he has told me if it does not work he will replace it with something else free of charge. I trust him and he likes working with them over most other things. It depends on there preference. You might pick something take it somewhere and then we will see the horror thread about how you have to pay for them to learn a new product. Makes sense to me
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
