So i've got the same issue.. mine are very stubborn water marks, have tried just about everything, made no difference at all!
Windex
Autosol
Metho
Acetone
Toothpaste
Dish washing detergant
Paint stripper
Any other suggestions?
Try an aluminium wheel cleaner that has hydrofluoric acid in it. A small amount only (less than 2%). High concentrations can be very harmful, even lethal. But you are very unlikely to find that in retail products.
Wash it straight off after cleaning your windows, if you leave it on it will etch or damage the glass. For removing bore stains there is nothing better. High concentrations cannot be stored in glass because of the reaction with it.
  • 4 weeks later...
Gumption worked for me after nothing else would.
Windex
Autosol
Metho
Acetone
Toothpaste
Paint stripper
  • 3 weeks later...
Windex
Autosol
Metho
Acetone
Toothpaste
Paint stripper
I pretty much tried all those things mentioned above after lots of research. None worked and was the biggest waste of time :rant:
And then I came across this Zaino Z12: http://www.zainobros.com.au/prod15.htm
It just works, its freakin magic. It took me a couple hours to do all my windows, but it was worth it and they look brand new now.
some of these things will melt the rubber around the windows or even etch the glass. and harm paint, or scratch the glass worse .
and extremely flamable after the fact in rags
if somethng like vineger and mircrofiber rag , the try megs Scratch X if that doesnt take it off then
use a commercial glass polish mine had osaka acid rain on it from the docks fixed it first try . just tape off the rubber to keep it black.
Im a spray painter and in the trade we use steelwool and windex. Windows always come up a treat. Do inside and outside then clean it like usual.
Its one of the first things i do to a car when i clean it up after purchase, its amazing how clean windows can make a car look so much neater.
You can also use razor blades to scrape up and down on a window, but just use heaps of windex while your scraping and spray more as you scrape. Steelwool should do the trick though.
Cheers.
Cheers
we do a similar thing where i work .... to remove any old glue from stickers or when doing a brand new car the paint on the windows ..
it seems to work okay but im not too sure on the whole "safety" and stuff of it .. personally wouldnt try it on my car
a point to note though is if the car has tinting DO NOT use windex on the interior glass
warm water with a good microfibre is much better, or something like stoners invisible glass - make sure its safe on tint!!!
Oh yeah i did forget to say not to use steelwool on the inside if it is tinted... But i have used windex on tint before without a problem? Just out of curiosity, why dont you use it, can it make the tint lift?? Wouldn't mind knowing more.
Cheers
its hard to explain but it basically looks like its peeling and stuff in spots?
i think thats what happened anyway, cos the tint on the familys XC90 was peeling and flaking off in places and when we showed it to tint a car their first reaction was - windex?
ive been told by people who install tinting and final inspection and other good detailers its just unsafe on tint
the people who installed the security tint/film on my house glass also told me not to use windex anymore - microfibre and warm water
the stuff we use to clean windows at my work seems like windex though - and it hasnt caused any damage and ive done more than a 100 cars with it ...
i just wouldnt risk it on any of my cars with so many professionals warning me against it
much cheaper in the long run to just buy a good MF and a good auto glass cleaning solution than to just use windex and find out one day in the future that it buggers up your tint imo
if someone with more knowledge could clear up exactly what it does to tint that would be great cheers.gif
Hi guys,
I'm a professional glass restorer and am constantly removing hard-water stains from car/boat windows, shower screens etc...
For stage 1 glass corrosion (95% of windows will have at least some of this), I use a product called Winsol Crystal Clear 550 (CC550). This usually removes most of the stains with ease. It works by dissolving the mineral build-up and is the quickest and least messy way of completing the job.
For more stubborn water spots (you can do it this way for light stains too), I use cerium oxide powder which is mixed with demineralised water to form a slurry. I then use a felt pad and polishing tool to polish the stains out. My polishing tool is worth over $1500 but for the DIY guys, you can use a felt pad (purchased from your local hardware store) attached to your household drill and remove the stains this way. It's a lot quicker than polishing by hand but if you have to go down that road, use Superfine Steel Wool (0000 gauge). This is abrasive enough to remove the stains but will not scratch the glass. I get all my supplies from these guys as they are the cheapest around http://fcwc.com.au/shop
Once the glass is restored, I apply a product called Sani-Shield which offers a lasting protection for up to 12 months from the hard-water stains forming again. A cheaper option is RainX
To clean the glass/window/shower screen, simply use soapy solution. You don't want to use anything too harsh otherwise you may compromise the protective sealant.
NEW WEBSITE HERE: http://onlinecleaningsolutions.com.au
Winsol Crystal Clear 550 here: http://onlinecleanin...ategory&path=51
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
