Hi guys,
I'm a professional glass restorer and am constantly removing hard-water stains from car/boat windows, shower screens etc...
For stage 1 glass corrosion (95% of windows will have at least some of this), I use a product called Winsol Crystal Clear 550 (CC550). This usually removes most of the stains with ease. It works by dissolving the mineral build-up and is the quickest and least messy way of completing the job.
For more stubborn water spots (you can do it this way for light stains too), I use cerium oxide powder which is mixed with demineralised water to form a slurry. I then use a felt pad and polishing tool to polish the stains out. My polishing tool is worth over $1500 but for the DIY guys, you can use a felt pad (purchased from your local hardware store) attached to your household drill and remove the stains this way. It's a lot quicker than polishing by hand but if you have to go down that road, use Superfine Steel Wool (0000 gauge). This is abrasive enough to remove the stains but will not scratch the glass. I get all my supplies from these guys as they are the cheapest around http://fcwc.com.au/shop
Once the glass is restored, I apply a product called Sani-Shield which offers a lasting protection for up to 12 months from the hard-water stains forming again. A cheaper option is RainX
To clean the glass/window/shower screen, simply use soapy solution. You don't want to use anything too harsh otherwise you may compromise the protective sealant.
NEW WEBSITE HERE: http://onlinecleaningsolutions.com.au
  • 4 weeks later...
Something similar, my windows have started to rub on something inside the door and its lightly scratched them. I wanted to get the windows tinted but I'm scared the windows might continue to rub and wear the tint off or that when they lay the tint down the scratches will be seen through the tint. Any tips for maybe removing the scratches or help it from rubbing the glass?
  • 1 month later...
its hard to explain but it basically looks like its peeling and stuff in spots?
i think thats what happened anyway, cos the tint on the familys XC90 was peeling and flaking off in places and when we showed it to tint a car their first reaction was - windex?
ive been told by people who install tinting and final inspection and other good detailers its just unsafe on tint
the people who installed the security tint/film on my house glass also told me not to use windex anymore - microfibre and warm water
the stuff we use to clean windows at my work seems like windex though - and it hasnt caused any damage and ive done more than a 100 cars with it ...
i just wouldnt risk it on any of my cars with so many professionals warning me against it
much cheaper in the long run to just buy a good MF and a good auto glass cleaning solution than to just use windex and find out one day in the future that it buggers up your tint imo
if someone with more knowledge could clear up exactly what it does to tint that would be great cheers.gif
amonia in windex kills tint, turns it purple and peals it off. use glass cleaner designed for tint or just clean water
  • 3 weeks later...
Hi ,
If your water marks are on the surface of the glass you can remove them using a product by CarPro called Ceriglass. This a Cerium Oxide based product mixed with a nano polish to allow it to work by machine or with the applicator in the kit.
I have removed not only water marks but seriously deep windscreen wiper scratches on glass with this and a polisher. Definitely worth a try.
Click Here for more info.
I have it on my chrome window surrounds and windows. I shall try the acetone trick on the chrome and windows and see how I got.
That Autoglym glass polish is as useless as tits on a bull
  • 4 weeks later...
Where do you get this "ceriglass" you speak of?
JDM Performance,
Your right about that. The product I recommended called Ceriglass does contain cerium oxide as well as nano abrasive acting as a lubricant.
For me, I just clean with soft sponge and liquid soap. Though, hard stains can be clean by ceriglass. There are lot car glasses care material who is very effective in removing car glass stain. Though, it was depend in your usage.
  • 1 month later...
  • 2 months later...
  • 2 months later...
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
