Hey guys just got a dyno last night ,
Cars running
*VG30 45V3 Turbo with Larger AP60 Housing
*FMIC
*Stock Air Box
*Walbro 050
*SARD FPR
*Untuned AFC Neo from Previous Stock Turbo
Ran on 12psi and spiked at around 14 for a bit a beggining due to lack of tune.
What do you guys think for these sought of mods should i tune the turbo a bit lower or should it be safe?
220KW sounds ok i guess
https://www.sau.com.au/forums/topic/243722-220kwwheels/
Cars running
*FMIC
*Stock Air Box
*Walbro 050
*SARD FPR
That is about the same as my turbo, i have standard ecu, afm, fuel pump and injectors and got pretty much the same power at 14psi which i run every day.
Once i have injectors, fuel pump, z32 and power fc installed i will up the boost a little.
https://www.sau.com.au/forums/topic/243722-220kwwheels/#findComment-4247594
Yeah well i wouldnt go past 14 even thats abit to much, I've already thrown one exhaust scroll into my Cat-Converter with Standard Turbos. Anything more then 13+ and it will smash itself to peices unless you have steel wheels on it? My Air-Fuel is all over the place compared to yours ill post a pic up now
https://www.sau.com.au/forums/topic/243722-220kwwheels/#findComment-4248735
Sounds about the same power as what I've achieved in the past with OP6 ceramic wheeled turbo.
The weakest link in your chain is probably the turbo - I don't like running the stock turbos at that high psi - some people's have even let go at 10 psi.
I suppose if it blows you can always just get it highflowed.
Just be careful though, sometimes when they let go, it can cause damage.
https://www.sau.com.au/forums/topic/243722-220kwwheels/#findComment-4248744
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
