My Skyline is terribly lonely sitting in the shed with only a Barina and a Lancer for company. So if it promises to be nice and not break anything and possibly use less fuel I'm going to buy it a new friend :P Namely an R32 GTR, should be a step up from the Barina lol!
Edited by Beelzebub89
  • Replies 84
Posted Images
my car is getting a 30/25 combo forged internals etc (built by lewis engines)
fuel system + injectors
ppg dogbox
complete suspension setup
new rims
paint job when its finished
bride seats x2
etc
and it goes in this thursday so i am stoked
done the ring lands so its the least i can do for her lol :D
Edited by R334door(s2)
a bit off topic, but who's Hypno the Rapist?
I can only say, "I have nothing to say!"
^^ Haha, funny stuff !
Santa Clause you C#$T, wheres my f*!king bike ?
I would also like a Plazmaman plenum, polished thankyou, as i like the shinyness............... :ph34r:
  • 4 weeks later...
My stock rotors were stuffed, so I thought I'd upgrade to something a little bigger...
380mm slotted AP jobbies for the win :D
My mate is having fun fitting/making adaptor plates this week.
Should fill out the 19" LMGT4's a bit better than the stock :)
I spoilt my r33 gtst skyline for christmas this year. She is currently trying them on to see how they fit
-gt3076r iw 0.82 housing, 56trim
- All custom piping to suit new turbo
-sard 850 injectors
- z32 afm
-044 bosh fuel pump
I am giving it to her early so next week she can model them. Bloody bitch costs me a fortune.
and then theres the girlfriend, she doesnt deserve anything this year. I have negative power with her.
IM going to buy mine an N1 Carbon blade, and matching side caps if the price is right :D
Having a carbon fetish at the moment... uugh. Although it wont be getting the presents till the New Year... she will be sleeping soundly over xmas/ny!
This christmas is a BIG one...
Race/Drag head from dirtgarage... cheers Paul
OSGiken RB30 package... hanging out for it...
HKS Twin Power & Harness
Need to sell the Trust 2.7ltr and race head if anyone is interested.... BIG build motor... no expense was spared. Will be in for sale section soon...
Edited by 34tomidnight
Gonna spend the day polishing and buffing the ol datsun while waiting for the food at the family bbq on xmas day
should hit close to 10,000klms by then so an oil and filter change.
other than that lining up a late x-mas pressie in the form of a HKS hi power exhaust and high flow cats by feb/march
IM going to buy mine an N1 Carbon blade, and matching side caps if the price is right :)
Who was i kidding...
Beer + Credit Card = Order..
Wonder if it will arrive before xmas...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
