hey guys
R33 1996 Skyline GTS Coupe NON TURBO
RB25DE
Full respray in and out including engine bay in VE Purple
Heavy Duty Clutch
Short Shifter
Blue Led Dials
Clear Tail lights
Custom Exhuast
Air Filter
Air Box
Coilovers
Diamond Vision Globes
Dynamat in Doors
Dvd Player
17 inch Wheels with Bridgestone tyres
In Great Condition, Paint is Only 3 Months Old
86500 Kms
5 Speed Manual
June 2009 Rego
Interior is Immac
Only Probs with the car are
The Air flow meter needs to be replaced, has a weird idle problem, sometimes need to rev the car a bit, just does it on idle sometimes
Small Scratch on Drivers door
Small Dent/Crease on bootlid
Sometimes has a knocking sound from inside the dash, have been told this is a common skyline problem, doesnt affect anything
Passnger airbag cover has warped from the sun slighty, nothing major
$12000 ONO needs to go
Contact Mario on 0430 129 882
https://www.sau.com.au/forums/topic/243950-r33-gts-non-turbo-12k-ono/
knockin neva heard a skyline doin that u should its not motor could have oil pressure problems could explain not idlen properly to gl wit sale anyway like those white rims on that colour but could want to lower price is still na...
the knocking comes from inside the dash, air con or heater box....nothing to do with the motor
everything has been check by my mechanic and auto electrician and the afm is faulty, oil pressure is fine
and as for 12000 it cleary does say ONO correct?
PLEASE READ!!!!!!!!!!!!!!!!
I HAVE REPLACED THE AIR FLOW METER, CAR NOW RUNS LIKE A DREAM, NO PROBLEMS AT ALL, ALSO HAD THE MECHANIC DOUBLE CHECK OVER IT AGAIN.....
11K MUST GOOOOOO
10500 NO COILOVERS......
My car knocks on start up too, it's nothing. It's like the air con is trying to open a vent (say feet) that's already open, and the gears just click over for a few seconds.
thanks man
thats pretty much on the ball there
Edited by Cro_boy_Mario
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
