hey guys
R33 1996 Skyline GTS Coupe NON TURBO
RB25DE
Full respray in and out including engine bay in VE Purple
Heavy Duty Clutch
Short Shifter
Blue Led Dials
Clear Tail lights
Custom Exhuast
Air Filter
Air Box
Coilovers
Diamond Vision Globes
Dynamat in Doors
Dvd Player
17 inch Wheels with Bridgestone tyres
In Great Condition, Paint is Only 3 Months Old
86500 Kms
5 Speed Manual
June 2009 Rego
Interior is Immac
Only Probs with the car are
The Air flow meter needs to be replaced, has a weird idle problem, sometimes need to rev the car a bit, just does it on idle sometimes
Small Scratch on Drivers door
Small Dent/Crease on bootlid
Sometimes has a knocking sound from inside the dash, have been told this is a common skyline problem, doesnt affect anything
Passnger airbag cover has warped from the sun slighty, nothing major
$12000 ONO needs to go
Contact Mario on 0430 129 882
https://www.sau.com.au/forums/topic/243950-r33-gts-non-turbo-12k-ono/
knockin neva heard a skyline doin that u should its not motor could have oil pressure problems could explain not idlen properly to gl wit sale anyway like those white rims on that colour but could want to lower price is still na...
the knocking comes from inside the dash, air con or heater box....nothing to do with the motor
everything has been check by my mechanic and auto electrician and the afm is faulty, oil pressure is fine
and as for 12000 it cleary does say ONO correct?
PLEASE READ!!!!!!!!!!!!!!!!
I HAVE REPLACED THE AIR FLOW METER, CAR NOW RUNS LIKE A DREAM, NO PROBLEMS AT ALL, ALSO HAD THE MECHANIC DOUBLE CHECK OVER IT AGAIN.....
11K MUST GOOOOOO
10500 NO COILOVERS......
My car knocks on start up too, it's nothing. It's like the air con is trying to open a vent (say feet) that's already open, and the gears just click over for a few seconds.
thanks man
thats pretty much on the ball there
Edited by Cro_boy_Mario
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
