can someone possible made me one??
Hey Aaron, It's actually easy, and fun.
I used paint. All you need is a base form of your car, save it, open it with paint and an hour or two of your time. :)
I can help you, but I am not that good so don't want to screw up yours. Plus you best know how your car looks.
Edited by VNS 24
Thanks, Rhys. I am still going to edit it and make it look more real. :P
How did the photoshoot go last night? You missed the basketball night. :)
Ended up being cancelled unfortunately, but I couldn't play basketball cos I seriously hurt my toe :/ One day I'll make it! Lol
lol i would, but im struggling to find a base lol
  • 4 weeks later...
Here's a few of mine
R33.4 in Bayside Blue
S13.4a Sil80
FD3S drift car
I also did a C110 Skyline a while ago, and am working on a pic with R31-35 in it, been meaning to do some V-Series as well :)
nah S14 series 2, gotta look closely at it :) I think i've done an S15 one as well, i'm currently working on the r31-35 one but only done the 31 and 35, a few V-series would be nice to do though
S13.4a Sil80
FD3S drift car
:thumbsup: . That would be great.
I wasn't happy with mine yet. Will play around when I get a chance.
Edited by VNS 24
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
