Just had a set of R34 GTR rims repaired which included repairing gutter rash (on the lip and the spoke which is a pain) and respraying. I think matching the colour of this rim is quite a difficult thing to do, but this repairer, through trial and error, has the paint code and it is a near perfect match.
Might save others a fair bit of time and hassle.
They are:
Matt Coleman
Wheel Solutions
Off Church St Richmond
0412 553455
I've used them twice and both times great results, and I have no interest in this other than to be helpful.
Yes yes, what did it cost???
I have a set of 18" Te37's that need repairs.
I reckon give the guy a call and get a quote as your situation could be quite different to mine. Are they painted or anodised?
  • 3 months later...
i'm thinking of getting my R34 GTT wheels done - how long does it take? and ball park cost cause I got gutter rash on two wheels. Did you have to balance your wheels afterward?
Best to call Matt at Wheel Solutions Richmond and ask him directly. He'll fit tyres and balance etc.
  • 5 months later...
I just dropped off my set of Volk LMGT Nismo rims. One is so damaged no other place would even look at it - Matt is really cool and agreed to have a look at it. I got my fingers crossed he will com through with the goods.
I just saw your wheel :) your right about it being quite damaged.
I just had my new wheels put on my GTR.
Matt and his boys do a sensational job. They're knowledge in wheels and fitments is second to none.
I just saw your wheel :P your right about it being quite damaged.
Yeah, Matt is a top bloke...mate, I love my wheel so much, I hope he can fix it...he said he's started on it and there's some hope....
I think if he can't fix it, then no one can. I got my fingers crossed.
did he fix it!?
Still waiting...the thing is, my LMTG4's are limited edition Nismo spec ones. There was only like 200 made, so it's going to be really hard getting another wheel so I am all in hope now.
  • 3 months later...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
