ok guys,
I've recently fitted a brand new Garret GT3582r with a .63 rear housing with the internal wastegate machined and a much larger wastegate flat added. Fabricated my own Bellmouth dump pipe, which is all mounted on a DMAX exhaust manifold.
My problem lies with the wastegate, Had it on the Dyno yesterday and found even the much larger internal gate was wide open with an 8psi actuator but boost was climbing well above 19-20psi and still climbing. I kind of expected a higher boost level than the 8psi actuator but wasn't expecting this much. Being an Unopened rb25det i am trying to keep it sensible. Yes i have checked to see if the dump pipe i made is fouling the wastegate flap and its not. hehe
My options are:
Either pull the turbo off and fit a .82 rear with an internal gate hoping this will help with the issue but i sacrifice any response i was trying to keep with the .63.
Fit an external gate (38-45mm?) to either the DMAX manifold or to the .63 exhaust housing and hope it gives me alot lower minimum boost level.
Who has encountered a problem like this and what's the best, cost efficient way of getting around this.
https://www.sau.com.au/forums/topic/244319-rb25det-gt3582r-my-predicament/
Check with BHDave, or search his threads. He had boost control issues with a GT30 0.63 combination. I suspect you'd be dealing with similar issues.
With that spec turbo you'd have to be chasing some pretty big power output, and an 8psi actuator seems seriously underdone. Go to a 0.82 A/R housing and fit a 14psi actuator at minimum - choose an actuator that is close to your intended boost and fine tune it with your controller from there.
If chasing high output from your RB25 then I hope your plans and budget extends to engine hardware upgrades - it will only stand being leaned on for just so long before something gives out.
Keep on it, and keep us posted. Very keen to hear how this combination works especially if you have a manual transmission. Hopefully your turbo supplier is willing to work with you on this one.
It may seem like a stupid turbo choice i know, but i really like the fact i can flat throttle it off the line in first and second and it's just fast enough not to break traction. A 3 litre bottom end will replace this motor once something let's go, Just eager to see how reliable this sort of thing will be. I really wanted to keep the .63 rear housing as i want as much response as i can get my hands on. I've had responsive turbo's now keep for some higher numbers with more aggressive power curves.
Any more info on external gate setups will be greatly appreciated.
yea i assumed the 3L would need a .82...Im not too concerned about that just yet as that's a fair while away. I want to get this layout fairly good first.
Anyone's thoughts on External gates welded onto Exhaust housing of turbo? My manifold doesn't have a large collection area where i can plumb into it.
Your custom dump isnt blocking the wastegate flapper is it?
EDIT: Its one of 'those' manifolds... ugh i really dont like that design at all...
Why didnt you go the other way? Choking the turbo is the wrong way to do it IMO.
Correctly sized rear housing (.82) and then a GT30 compressor wheel (500hp) would be the way to do it... or if you REALLY want proper response, .63 with the GT30 (GT3071/3076 style) - not the GT35!!!!
Then sell the turbo, and get a GT35 when you get a 3ltr. :blink:
They hold value near enough, and with a GT30 - 270-280rwkw... the RB25 you might find will probably last you a fair few years...
So you would be waiting a fair while i reckon for that 3ltr and in turn can go all out with a big GT35 on a full build, 1.06 housing, 400rwkw etc.
Remember the GT35 wheel is a 700hp wheel or there abouts. Putting a .63 on there means your basically hurting turbo output for no real reason (response doesnt count as a reason if you get the correctly sized compressor wheel).
All of that restricting will bring the flow down to a stab of around 550-600hp worth of top end air. Not good at all as you then bring heat, backpressure and other nasties into the equation.
Just my thoughts on it
not sure why it is overboosting, have a good look at the gate and actuator.
there is a jpc vl with 0.63 housing on gt35 running 9's (370+rwkw), so it can be done, just not the obvious choice. (or logical, but who can argue with the results)
the turbo you want would be a gt3076, good front to rear ratio with regards to gas flows, no point of the gt35 82mm front with a gt30 rear wheel. aka gt3082 bad match
Edited by RB30-POWER
Have experiences with an rb25 with an 3582 .63
external gate 38mm, holds beautifully, which just a dual stage bleed valve (no ebc as yet)
Logic would tell you me that if your having boost control issues its from your wastegate or bc.
size of the rear end will just cause lag etc as explained above.
3582 may seem big for a stock 25 but comparing to say a GT30, the 35 may come on a bit later but when it comes its well worth the wait, just an effortless tyre fryer.
So its 100% that the housings and/or turbo aren't modified? :D
Was it done on PULP?
Cause i mean, if people have modded housings and non-standard fuel, it totally changes the dynamics
So its 100% that the housings and/or turbo aren't modified? :)
race fuel, modified + 50mm external gate :D
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
