Ok. Well the other day i left my car at the train station (had to be in the city and it was peak hour so i thought i would be better off training it) I parked my car all was well. I got back to my car about 2 -3 hours later all was still fine, or so i thought. I parked my car at home went out blah blah blah when i came back my sister who parks behind be had left a written note saying that "someone looks like they have tried to break into your boot, or into your car via your boot." (i never saw it at the train station or at home because who checks that before they drive?) I was shocked and went out and checked, low and behold some douche had shimmied off the boot lock (there are about three key marks where they have pried it off). Nothing was stolen and they have not been able to get into the car if that is what they where aiming to do (why not just smash my window?) But now i am left with a hole where the lock was how can i fix this? I assume that i cannot just buy a new lock because my key wouldn't fit it? Is there away around this? I was thinking to just get it al filled in and resprayed and thus deleting the lock then just using the boot release to open the boot in the future? Any suggestions or tips would be great.
P.s It is a r32 gtr, if that helps with parts ideas.
Cheers
https://www.sau.com.au/forums/topic/244438-what-to-do/
Unlucky mate, Never had any attempts on my car yet so I've no experience on claims or anything. But this could be a good thing, get the hole covered and remove the badges from the back of your car for a stealth look, you know you've always wanted to :(
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4255524
You should be able to buy a new lock either secondhand or new from Nissan. Take it to a lock smith like "Diamond Lock And Key" in Osborne Park (Main street) and get them to redo it to accept your current key. Saves you from having to have different keys for different locks.
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4255751
Hey champ What F(*ks they must prob going for a sound system which is known to happen alot! their not much you can do besidse try to park it else,
sucks tho cnart do much
(Shave the boot lid so no lock use the lever) ?
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4255882
Maybe you can get a new key barrel and take it to the locksmiths and they will cut the barrel to your key.
Not sure how much the barrel will cost itself, but it beats getting a secondhand one which means you will have to carry an extra key.
By the way, my one is deleted.
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4256662
thanks for the Suggestion Brad. So any gtr32 key barrel will do? Or can i use like a r33 one or any other models one? and then they will just configure it to take my key? Any idea how much that will cost? it will be that or deleting the lock i guess depends on how easy either one is hrmmm. Suck like why couldnt they have just left the key barrel after they f**ked with it it would have been no use to them :).
https://www.sau.com.au/forums/topic/244438-what-to-do/#findComment-4256789
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
