Hey guys,
Getting a new rear wheel bearing for the R34. It seems no one has done this on these forums and written about it.
Can any one advise on if the bearings listed on ebay will also fit a R34? I will post the link.
I have already ordered from Victoria and fingers crossed it will work.
Can anyone confirm?
http://cgi.ebay.com.au/NISSAN-SKYLINE-SILV...rts_Accessories
The seller is 99% sure it will fit and tells me the shaft size, does anyone know the shaft size for GTT rear wheel?
Its meant to look like this
http://www.skylinepart.com/ekmps/shops/jap...es/img_1316.jpg
Anyone help?
Edited by DECIM8
https://www.sau.com.au/forums/topic/244969-wheel-bearings/
Nissan are useless. Went from quotes between two places from $255 and $280 they would match it at the other place however.
Rockdale Nissan would not supply a product code and was anoying the shit out of me, however with a VIN Artarmon will match it, Thank god!
Anyway thanks to all who helped, Bearings aftermarket dont exist for the R34!
Cheers
Nathaniel
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4266253
did you then click the find part number? Because thos numbers there arnt actual part numbers just a description, as they are both hubs for example.
You're right, i bollocks it up. Ignore previous post.
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4268697
Got the Part number from nissan today (had to pay $255 to get it.. i.e buy the part before they would supply a code - have to love Nissan)
The part number supplied was correct, however a friend has installed it on his R34 and the bearing is the wrong size. He made a fitting to fit within it.
Looks like a giant game of shambles.. I am not looking forward to fitting it.
Thanks again for the help Kotter
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4271958
is 255 for both sides of the rear or just one?
jebus...
also why are you replacing them? i've never heard of the wheel bearings go in any skiz to date, unless they were smashed.
On a side note, make sure you correctly fit them. Buggered wheel bearings = wheel comes off
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4272056
Just one.. Ball bearing in a housing rip off! Cant drive it like this tho!
Yeah they are buggered as atm .. So will have to put them in correctly.
I hit a curb, drive with bad camber and often use the handbrake.. this is why.
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4272643
had a front left go in my gtst. It's not uncommon. The front right in my s13 sounds like it isn't too healthy either.
They will all let go eventually. Add extra load (track work, big offset) and it will be sooner rather than later.
Seriously though. All the bearings in the car will most likely be manufactured by NSK. And all of their bearings have a number stamped on them. Take that number to any bearing supplier and they will be able to get the right one.
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4274166
  • 1 month later...
from memory 38-40mm shaft i believe.
you should really replace both sides mate as if ones gone other wont be too far...... you can get a much cheaper price from bearing places than nissan as ntn supplies bearing for nissan so same thing just maybe diff part numbers
https://www.sau.com.au/forums/topic/244969-wheel-bearings/#findComment-4358831
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
