Well, as some of you know I was fortunate enough to fly over to the USA for the 2008 SEMA show earlier this month!
After 11 nights in America Im glad to be back on Australian soil but the trip was awesome!! I'll have memories of Vegas, the SEMA show and so much more for many years to come!
I have attached as many photos as I can (I took over 600 pictures) to give you a taste of just how amazing SEMA and Las Vegas are.
Enjoy :P
https://www.sau.com.au/forums/topic/245166-bullet32-goes-to-the-usa/
Very cool. I've started saving to go next year with some friends. Any tips?
You cant get in to SEMA if you arent registered as part of the international automotive trade or media.
Stay at either Caesars Palace or the Belagio, they're the nicest hotels that we went through.
Take as much cash as you can but dont spend any of it on gambling... Vegas is an expensive city!
If youre not taking the missus - make sure that you visit "The Spearmint Rhino Club" - very expensive cover charge and drinks but well worth it :(
Already got that covered.
Accommodation is covered, one of the guys cousins lives close enough and is fine with us crashing at his place.
I'll keep this in mind... especially the "spearmint rhino club".... sounds intriguing!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
