hi guys
i recall the R33 GTS-t has an auto-locking system for the doors when the car exceed 40km/h
im not sure abought r33 GT-R......
what about the r34 GT-R? does it come standard?
gee guys im suprised no one has an answer for this thread
doesnt ANYONE here own an R34 GT-R????
hi guys
LOL!
You do own a R34 GTR right..? You could have just tested it yourself :P
I know I have to lock the doors myself in my R32.
My 34GT autolocks as soon as you start the car, not sure if its a stock feature though.
Just out of curiousity does anyone know if there was any r34 that came factory with no keyless entry?
keyless entry or no keyless entry?
you mean a magic fob where you stand near the door with it in your pocket and it unlocks for you?
No i ment did any r34 come factory without keyless entry. Keyless entry as in you press the button and the car unlocks.
Nissan reakons mine didnt. And that i dont have a immobiliser. But they were only going but what there computeres said
That is a confusing question. but most R34 GTRs do not have factory keyless entry. there was a dealer option remote central locking that comes with a nice little remote with GTR emobossed on the back. there was also an immobiliser option that has a proximity immobiliser reader in the key barrel with the immobilisers mounted in the key themselves.
Yes sorry i was having trouble wording it. So is that the same with GTT's and GT's?
I only ask because my remote isnt stock, and im having problems figuring out if my central locking is aftermarket or not
Edited by Darkplague
Okay I don't know if this helps in any way, or if it'll confuse people even more.
But my 1999 R34 GT-R V-spec comes with remote locking/unlocking, keyless entry, whatever you want to call it. As mentioned it comes with a FOB with a GTR logo on the back of it.
My car does not auto lock when I start the car or drive.
My best mate has a 1998 R34 GT-T and his comes with a FOB too for central locking AND his car auto locks the doors the moment he starts his engine.
Is there a way of enabling the auto-lock feature?
Yeah thats what my 1999 r34 GT does to, autolocks soon as the engine starts.
Accept i wanna know if theres a way of disabling it.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
    • okay, so I figured this out, removed needles and reinstalled after swapping the gauge face on my triple gauge for my ER34, all work and look good. I tried to do the same for the main cluster, but the main cluster gauge faces are dished, the replacement gauge face are flat, so due to the dish in the org face ,mounting backing plate (clear) and depth of the needle, the flat gauge face will not work. I notice that R34 gtr gauges are flat, appears to be different clear backing plate that aren't dished. are these available, or what have others done to install flat gauge faces?
