hi guys
i recall the R33 GTS-t has an auto-locking system for the doors when the car exceed 40km/h
im not sure abought r33 GT-R......
what about the r34 GT-R? does it come standard?
gee guys im suprised no one has an answer for this thread
doesnt ANYONE here own an R34 GT-R????
hi guys
LOL!
You do own a R34 GTR right..? You could have just tested it yourself :P
I know I have to lock the doors myself in my R32.
My 34GT autolocks as soon as you start the car, not sure if its a stock feature though.
Just out of curiousity does anyone know if there was any r34 that came factory with no keyless entry?
keyless entry or no keyless entry?
you mean a magic fob where you stand near the door with it in your pocket and it unlocks for you?
No i ment did any r34 come factory without keyless entry. Keyless entry as in you press the button and the car unlocks.
Nissan reakons mine didnt. And that i dont have a immobiliser. But they were only going but what there computeres said
That is a confusing question. but most R34 GTRs do not have factory keyless entry. there was a dealer option remote central locking that comes with a nice little remote with GTR emobossed on the back. there was also an immobiliser option that has a proximity immobiliser reader in the key barrel with the immobilisers mounted in the key themselves.
Yes sorry i was having trouble wording it. So is that the same with GTT's and GT's?
I only ask because my remote isnt stock, and im having problems figuring out if my central locking is aftermarket or not
Edited by Darkplague
Okay I don't know if this helps in any way, or if it'll confuse people even more.
But my 1999 R34 GT-R V-spec comes with remote locking/unlocking, keyless entry, whatever you want to call it. As mentioned it comes with a FOB with a GTR logo on the back of it.
My car does not auto lock when I start the car or drive.
My best mate has a 1998 R34 GT-T and his comes with a FOB too for central locking AND his car auto locks the doors the moment he starts his engine.
Is there a way of enabling the auto-lock feature?
Yeah thats what my 1999 r34 GT does to, autolocks soon as the engine starts.
Accept i wanna know if theres a way of disabling it.
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
    • I'll sit down and get a post together 😁
    • The factory oil pressure sender is no longer in the car that's what is confusing me. In the Taarks adapter I have an aftermarket Bosch style pressure/temp sender and the factory temp sender only. Oil pressure is perfect. Where does the factory oil temp sender go to if there were never any gauges? Why was it there from the factory?
