I don't quite get the obsession with japanese rims ... what's the big deal? Most of them look plain and boring. Sure they may weigh 5kg less for the set but unless you're racing the car, who gives a damn ?
Oh and DTM is an NZ brand afaik
they are forged, stronger and lighter end of story. if you dont care about that, dont knock the people who do. its the oldest argument in the car scene and i have never understood why people who want to cheap out think they can bash the people who dont mind spending 2750 bucks for wheels.
i checked ou those DTM wheels and IMO the are heavy, ugly and the offsets are terrible. who in their right mind would put a +42 offset wheel on their RWD car? i dunno, just picture how heavy an already heavy wheel will be with 30mm of backspacers or hub adapters on them so they dont sit so far up in your fender that they are sslapping your suspension.
my advice, browse the internet, find yourself a used set of genuine, non-knock off, forged wheels on ebay or yahoo auctions.
another option: for 2300 or so, complete custom wheel (CCW) will make you whatever the hell you want. thats the route im going. (18x11 +10 for a 305mm tire.)
https://www.sau.com.au/forums/topic/245331-dtm-rims/page/2/#findComment-4275495
japanese rims are built to a much higher safety and performance standard than china crap... it is regulated over there.
also they look 11ty times better and perform 11ty times better
https://www.sau.com.au/forums/topic/245331-dtm-rims/page/2/#findComment-4275811
The weight isnt a concern, its a street car so i dont see why it really matters?, but i guess concedering its only a rb20 N/A the less weight the better lol.
Im more interested in the quality and looks, I personaly really like the look of japanese rims, mainly the volk/rays look. Nothing else has stuck my fancy as of yet.
Deffently agree with joeyjoejoejuniorshabadoo they look 11ty times better.
Edited by Darkplague
https://www.sau.com.au/forums/topic/245331-dtm-rims/page/2/#findComment-4276398
Lol dont know what you were looking at. They are actually pretty damn light for 18 inch rims, and what are you talking about stupid offsets? I got the rears in 9.5 inches wide in +35 offset and front 8.5 inches wide in +29 offset. Dont need any spacers at all. Research before you post up complete garbage.
Btw got mine sitting in my living room. They look hot in Gloss Black and will be going on the car tomorrow morning :)
https://www.sau.com.au/forums/topic/245331-dtm-rims/page/2/#findComment-4276477
I've had a set of DTM wheels for 5 yrs now. There not bad the only thing that i don't like about them is I have seen quiet a few cars now with the same wheels as me. Other than that they have lasted ok. The clear on the rim is lifting a little but I would expect that from a cheap wheel. I think there pretty strong I have split the side wall on 2 (different occasions) pirelli p-zero rossos from doing over 200km on rough roads (don't like the tyre at all), and the rims are still good. So yeah if that is your budget than I would say get them. That said, I think it is worth it so save a little longer and get the wheel you want.
https://www.sau.com.au/forums/topic/245331-dtm-rims/page/2/#findComment-4278001
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
