Chi100188 Posted November 20, 2008 Share Posted November 20, 2008 Hey guys im looking at purchasing some rims for the R33 these rims, the size of these rims are Front 18x9 +18 and rear 18x10 +18 car is a R33 GTS with GTST front brakes Cheers Chi Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/ Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted November 20, 2008 Share Posted November 20, 2008 they will stick out a fair bit on the rears, say, close to an inch... fronts should be roughly flush Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4274666 Share on other sites More sharing options...
Chi100188 Posted November 20, 2008 Author Share Posted November 20, 2008 hmmm would i be able to fit the rears with rolled guards? or do i have to get wide body to fit these? Cheers Chi Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4274782 Share on other sites More sharing options...
dori34 Posted November 21, 2008 Share Posted November 21, 2008 rears will fit depending what size tyre you run & how much camber you got. Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4275252 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted November 21, 2008 Share Posted November 21, 2008 an agressive roll should see 'em fit with 245's or so, i wouldn't camber them too much to fit as when you drop it there's too much camber as is.... Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4275799 Share on other sites More sharing options...
krzysiu Posted November 22, 2008 Share Posted November 22, 2008 I would think they will stick out quite a bit. Probably best to get better offsets because dialing in negative camber will kill your tires a lot quicker. If your car isn't lowered you wont have problems, except for scrubbing at the front, but when you want to lower it then you will have to do something more. Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4276977 Share on other sites More sharing options...
dezz Posted November 22, 2008 Share Posted November 22, 2008 Comparing them to my current wheels, your fronts will stick out an extra 10mm. I'm running 235's on the fronts and have not rolled my guards, but scrub the liners under full lock, and just under full lock depending on how the car is sitting etc. I'll be rolling my front guards as if I was to hit a decent bump (or ripple strip on the track) with some lock on, they could hit the guards, so I'd suggest you doing the same (as well as removing guard liners). Your rears are gonna extend outwards an extra 10mm over mine as well, and mine were protruding the guards by quite a bit...you'll definitely need a fair bit of flaring to get them to fit. Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4277180 Share on other sites More sharing options...
DECIM8 Posted November 22, 2008 Share Posted November 22, 2008 Will stick out run some seriously narrow tyres and maybe some slight flare. it will fit but will require work - will look mint when done tho Link to comment https://www.sau.com.au/forums/topic/245765-will-tehy-fit-my-car/#findComment-4277302 Share on other sites More sharing options...
