hey guys just put new split fire coil packs in my car and my mate did a compression test on my r25det s2 while he was at it
it got 150 - 150 - 150 - 150 - 100 - 150 - 150
he put oil in the bore and it went up to like 130-140 he said.
He is saying its probably the rings, but best to take it to a shop to find out.
what are my options? how much would it be for a mechanic to rip my engine apart find the problem and fix it?
budget is fairly limited, cheapest safe option here is what im looking for that will fix the problem.
any help / suggestions appreciated
https://www.sau.com.au/forums/topic/245868-low-compression-woes/
id be checking it out definatly, its only gona get worse, all other cylinders read 150psi, and that one is 100. there should be only 10 percent variance between then in any case...
id be rebuilding it as its obviously not healthy. sorry to inform u mate...
The harder you push it, the worse it will get, you will end up with a massive blow by machine...
do a leakdown test as it could possibly be a bent valve or a head gasket problem... i think its not due to the comp bumping up with the oil test
Edited by den001
Out a little bit of oil down the spark plug hole and run the test again.
If it comes up with 150, its your rings.
Oh. hahaha.. sorry.. I should start reading threads.
Yes. Rings it is
Edited by GTS4WD
Yeah as said above, cheapest option if you don't want to rebuild it is to just buy another engine and then sell off your old one. If you can do the job yourself with mates over a weekend (it aint that hard), it will probably only end up costing you $1000 once you part of the old one.
We did it to my mates a month or so back.
where can you pick up replacement engines for that price? sounds good.. im just getting my engine tuned and gonna drive it til it doesnt wanna be driven i think -_-
i wouldnt mate, it will get so bad it will start to missfire badly, after this if u give it a good flog you risk blowing the oil up thru the breathers and leaving the sump with f**k all, it will spin a bearing and they you will be up for even more cash to fix it...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
