Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
why all the hate on abit of lag, get it in the right gear and the thing will never come off boost. The t04z would be fine around a track as long as its not super tight. The t04z will make upwards of 650rwhp so its no where near the limit either. People under estimate an extra 80hp top end :)
pretty much the same engine/turbo but one has 6-boost twin scroll and one has china manifold and a dodgy gate
shows what a well set up manifold/gate/boost controller combo can do...
So top graph is brockaz & another setup - both GT35's yeah?
If so, first graph is very interesting in that brockaz setup comes on noticeably sooner than the setup with much better parts.
I wonder what the reason behind that is... interesting
sorry should have explained
top graph
gt26wa = brockas gt35r 0.8x t4 rear on china manifold
1bxx056 = my old gtr t04z divided .084 housing 6-boost
bottom graph
builtr = brockas same setup but t04z instead
Using the same boost level is i dunno, arguable.
Remember the turbo's have different areas of efficiency and so on.
Best of running them both where they both perform best and comparing off that IMO.
Indeed arguable. Effiecent range on the GT35 is probably 28 - 30psi and 35 + on t04z.
Brockas like most probably not keen to push to those levels.
top graph
bottom graph
All your graph comparo proves is that brockas china manifold / setup is crap compared to 6boost and your setup.
GT35 on your setup would have rocked.
ps. nattalotto get the f**k out of this thread unless ur car is going to be on the road before 2056
LOL coming from the guy that never raced his 26 !!! Simon N has times you got wannabe ......
Final word
IN PERTH GT35 smashs the t04z on RB26. Best single t04z time is like 10.8 on a fully built motor ??
There is more then one GT35 RB26's quicker then that IN PERTH.
that was my point... he need to get daddy to buy 6-boost and tial gate :-)
we dont think silvias are worth mentioning :P plus run a decent mph in your stripped out drag car when the street cars monster you top end ;)
top graph
bottom graph
Ah ic ic - makes more sense now :P
Would be interesting to see the GT35 on a good setup i think, one thing that's missing from the comparo's haha ;)
so whats the best result on roller dyno (no happy hubs) for a gt35? like 530rwhp (dcieve)? and best t04z is 625hp?
big difference, some like medium power and some like more power than that its the way it is :P
Nert.
We pushed the 35R as far as it would go. We put 28psi into it and a couple of degrees ignition timing, it made 4hp more.
510rwhp on that dyno is as much as the GT35R will make on my car.
586rwhp is as much as the T04Z will make.
Both setups will not make any more, no matter what we do.
The T04Z should come on a lot harder but thats the fault of the shitty wastegate. Having said that, the wastegate was exactly the same on both combos.
Same could be said for the GT35 as well don't forget
Interesting. Wonder were the restriction is. 510 does seem towards the limit of a gt35 on a 2.6 with pump.
Not sure how many 26's go over 586 with a t04z either.
so whats the best result on roller dyno (no happy hubs) for a gt35? like 530rwhp (dcieve)? and best t04z is 625hp?big difference, some like medium power and some like more power than that its the way it is smile.gif
Peak power does not determine how fast a car is, sure its a good indicator but its not everything. In brockas case the car could be faster with the less HP. The lose of over 110 hp through the lower range is a big difference too :P
Nice result Paul, you should be pretty pleased. As you've already mentioned both your 35r and t04z are laggier than they 'could' be (comparing to the results of others) be so some tweaking of the boost control etc should beef up the 4-5000rpm area nicely.
All the talk of which is quicker would be quashed if someone has the time to plot both of pauls plots in excel then calculate the average power over the usable rev-range (say 5k - revlimit).
big difference, some like medium power and some like more power than that its the way it is ;)
So comparing my straight fit cam, stock head rb26 with your all out jun 2.7? :P
all im hearing is waaa waaa waaa i can't crack 130mph in my lightweight drag car with a 35R tongue.gif
Lol.
Big MPH and slow time just shows how poor the car is setup or how bad the driver is :P
I could wheel spin the track and run bigger mph, what does that prove ?
Much rather perfect use of power, fast time with low mph !!
Also quite confident my "low mph" light weight car would be quicker then the 130-135 mph GTR's in the top end as well ;)
If you can't run into the 140mph range with a GT35R, you aren't trying hard enough ;)
The 600+hp dyno plot isn't relevant to the comparison we are seeing here... a before and after with the same car and same dyno, run to the limit each turbo will make with that setup has to be the most fair comparison you can get - surely?
It represents 15% more power with 19% more revs needed to reach 20psi (to rule out the boost controller differences, and make a bit easier on the T04Z). Far cry from earlier in the thread where people were implying the T04Z is comparable to a GT35R in spool! I'd love to see a GT4088R compared with these things :P
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
