Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
It shows another thing as well, not everything is shown night/day on a dyno sheet when talking circuit applications.
Plotted on graphs they might look very similar, however actually driving them on/off throttle is something else again
What would be very interesting is seeing the motors held at 5000rpm with no load then stomping on the loud pedal and comparing the curves that way.
I'm surprised no one does this as it would be a great way to demonstrate transient response. Obviously the same ramp rates and gearing would need to be used for it to be a useful comparison, but I don't think that would be too hard to do.
Edited by Rolls
  • 1 month later...
Gccg are fitting the TO4Z 63trim comp wheel into the GT3582r and are calling it a GT3566r , I guess this is mainly for the XR6 ford turbo engines as a up grade , But i was wondering if this turbo would be a good compromise between the Gt35r and the TO4z in giving the best of both worlds in both turbos , Garrett has just released the GTX3582r turbo so that also looks to be a option , closer to a TO4Z.
  • 7 months later...
I know its been a while since this thread was alive but i thought my results would spark up some debate again.
R34 GTT
RB26/30
Gt35r .82 rear
3.5" exhaust
exhaust side of head port matched and polished.
CP pistons
spool rods
9:1 comp
25psi
390.1rwkw
Nice result, which fuel?
believe it or not its on 98ron Shell Vpower =]
Never got a chance to test it on e85, especially after the twin 044 pumps and teflon fuel lines. Had a offer to buy it that i couldnt refuse. Deposit paid and the car picked up next week.
So sad =[
I never understood why people built cars like that and then sold them straight away, what is the point in spending all that money otherwise?
So sad =[
These things make even more with aftermarket cams, a lad I know has made >400kw @ hubs on slightly less boost with an RB25/30 with a .82a/r GT3582R on 98 :)
  • 8 months later...
I never got to play with cams but judging by how efficient the setup was. Cams would of saw power everywhere throughout the rev range. Definitely worth while!
  • 3 years later...
I know its an old thread but I have a question with anyone that are or were running TO4Zs.
I am finding mine a bit oil blowy with a 1mm restrictor in a -4 oil feed line. Anyone have any issues running a 0.8mm or less restrictor. I am still on a run in tune with a 5k limiter and pushing 5+ bar engine oil pressure, so thinking might have to reduce the flow even more seeing that the zeds don't like anymore than 3 bar in their feed line. Any wisdom would be much appreciated.
Edited by XGTRX
I don't think you should run a restricter like normal gt turbo. I'm not running 1 on my t04z and I'm not having any problems
What size feed are you running, I am thinking maybe my -4 is to big
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
