after Guy fitted my BOV on for me (HKS SSQV) my car was getting more km's out of a tank, and it was backfiring when i gave it stick causing the flames... awesome...
is genuine HKS... Sunny dude, i would take out your BOV and just sell it and get a genuine HKS... china BOV's = super ghey
100km's less out of a tank is not worth the wank factor, more km's is though
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4287749
  • Replies 50
Posted Images
As Bubba said, it wont run rich unless the BOV is actuating.
If the BOV is actuating under load. Its not tight enough.
Properly working Atmospheric BOV's will only 'smoke' and run 'rich' when they need to "Blow off" extra air. (And that's to do with changes in Load)
Just tighten it, make it work properly.
That 'Extra' fuel coming through the exhaust would have just gotten burnt by an unloaded engine anyway. Which will not effect your economy. Really, its not extra fuel, because it was going to get injected anyway.
(On a side note, AT A GUESS, because the princeples of induction may counter this - if you plumb back a bov in front of the AFM, you will read that portion of air twice, and then there will be 'extra' fuel injected.)
Your smoke on load is a sign the BOV may not be operating correctly.
I think im just repeating what people have said ?
However there are some myth's being said too.
its got nothing to do with the bov spring being tight enough.
its got to do with the stock bov recirculates the air back into the intake pipe. atmosphere bov vents to the air. therefore less air in the intake
less air + same fuel = running rich. its very common problem, atmo venting bov are complete wank factor nothing wrong with stock bov i had no issue running one with 350rwhp and if yours is leaking get a set of gtr bov
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4287847
Are you saying all atmospheric bov's will reduce fuel economy ?
Retract this, ive realised stock setups dont plumb back infront of the afm:
Edited by Tezzah
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4288010
i got my stock one back on and the car drives better too also it more responsive... plus the pod makes the CHOOO sound at lower revs
Now you can hunt down that dude who sold it to you and make him eat it...
with his anus...
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4288193
The guy was saying that he was getting lots of black smoke UNDER LOAD not on liftoff. Puffs of black smoke on liftoff or gearchange is normal with an atmo bov that hasn't been tuned for it. PLUMES OF BLACK SMOKE UNDER LOAD IS NOT JUST BECAUSE THE BOV IS ATMO. Something is wrong and it is most likely leaking when it shouldn't be.
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4299115
wank factor?
Whats wrong with atmo bov's? I quite like mine.
As long as they arent overly loud.. they sound nice =)
If you like the sound of Harpo Marx sneezing or the amplified noise of a mouse being squashed, I'm sure they sound real good to you.
These noises are in no way associated with any kind of 'power' experience. If you like repeditive 'pachoo' and squeaking noises then Fisher Price has a great range of electronic musical toys on offer this christmas.
I reckon they should make them sound like farts at least then they have better comedy value.
My kids (incuding the 3yr old) now point at cars and say 'ricer!' when they hear these.
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4303920
just slap on an intercooler sunny, then dose it....lol
Least then you can be a sick kent!!
Who cares guys really, if you like the little sqeak sound, go for it... i prefer the dosing vl sound, not cuz i like vl,s i just like the sound, but that deep bass dose, not that shit high pitched annoying dose...
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4303976
I love the idiots who still think that power is measured by litres...
HURR YOU HAEV A 2LITRE? HAHHAHAHAHAH MY CAMRY IS DAT POWERFUL MUST RUN ON RICE
Can your camry do 1/4 mile in 12 seconds?
Edited by Haunter
https://www.sau.com.au/forums/topic/246503-bov/page/2/#findComment-4304262
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
