  • Replies 138
got afew cars on the go. 82 datsun 720 kingcab getting shaved etc, ED falcon shitbox (currently on $150 19s not the 17s in the pic)i converted to manual, fitted an LSD and i got the head off atm doing a port job and upping the compression. the stagea which i have coilover and R34 brakes to fit soon (disgustingly high with 18s) then theres the beast. my 1968 VW squareback
James, that's a sick buggy! I've been thinking about getting my electric one up and running again....just gotta replace the seals and oil in the rear shockies and replace/repair the munted cells in the battery packs
so you're handy with VW motors then?
my dad and i have a off road buggy. basically a 67? dub with shell and floor pan gone with rollcage in place. got a fastback on the way for the motor (1600) and rear suspension set up.
how hard is it to make it carby and do you have and tips on modding for power. we're in a comp with my uncle and i want to smash him lol
his is a bit.... crap. but its running a datto 200b motor with twin SU's. Note my awesome helmet/goggles
yeh very handy. i got a 72 fastback too, thats locked away in my dads mates garage til i got a garage build (8 months ago hahahHAHAHA jokes on him). most fastbacks are dual carby and its rare to see a bosch fuel injection system still installed and running. use the type3 trans too they are abit stronger than a beetle one and have better ratios. might be worth using the pancake engine with dual carbs so if you snap a fan belt you dont cook the engine
basically bigg headers, big exhaust and the right amount of advance is the best increase without massive coin. on my old beetle i very lightly ported and cleaned up the intake port and then the same with the exhuast ports but polished the hell outta it to near mirror finish and the rest was bog stock apart from a 009 dizzy and a good tune and she flew!
I NO NAHSING!!!
the type3 rear suspension (if its an IRD model and not swing axle) is more beefed up from the beetle too, there 2 rear spring plates (trailing arms) instead of one so there less camber change though its range of motion. also the drum brakes are bigger
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
