Hehe.. it sounds like it's going to be a skyrice australia meeting at Gavin's next week.
My cars down their the whole week (because I can't do down during the week and my b/f can't get time off) so Sinbad (car) is having a sleep over at Aunty Manda's and Uncle Gavins :uh-huh:
  • Replies 181
well, i got my last service at the new nissan service depot at wooloongabba and i couldnt be happier with it
they were cheap, went way above and beyond (they greased every lock and hinge in the car, i aint never seen that done before)
did an awesome (4) wheel alignment and was still cheap as (as well as they let me know a few things i need to do next time (leaky gasket, missing bonnet rubber))
maybe they cant do all the hitech stuff gavin woods can, but screw driving all the way down the coast every 5000k
ill be back there for my next service for sure (props to woman for finding them)
yeah i was wondering why you added the last comment ;P
dont read qgl much anymore, mainly because its full of shit now and the flamewars dont exist anymore. The funs gone and the nazis reign.
I was going to ring today but rang outta time being sick. But I have to find someone taht can fix the air cond fan in the dash to work again it died and if I get this fmic shortly I would like someone to put it in, as I'm short of time. Mainly just want the odds and ends fixed and the car tuned up and service. I was planning on doing it at the same time,a nd getting it dyno'd and running smooth, just wondering if gavin would be able to do all this, or would I have too take my car to like 10 different car shops?
yeah i read your dash read me, its pretty easy to take apart, but the thing is I dont ahve much time these days. tadoy I wasnt felling 100% so I went out and got some cash and hunted around to see where i could get teh air cond fan checked and working. The turbo timer is just I have weird the wires to the wrong one, optput 2 is on the igition and not the other wire. fix weekend.
intercooler and piping shouldnt be too hard just need grinder, drill and a coping saw/jigsaw. but first have to see what piping i get with the kit. the bar and lights are easy to take off, but its a pirck to get the bar back on.
I restored a hj ute from 3 write offs,a nd painted it, so I do know a bit about handy work. Learnt most of it as a kid at dads work. Just atm Its cheaper for me to get someone else to do it while I earn the dosh, and if its all put together and serviced then tuned and dyno'd I get a car thats got the works done in one go. None of this every weekend drop off and check crap or get it serviced then next week tuned.
Time is the main issue I have, its a problem to get stuff done when 14 hrs of the day your at work, and 12 on the weekends. just been lucky lately to be able to have sundays off beacuse the dollar is up and not much coming tinto australia atm.
yup, time is money.. i wasn't really implying you were lazy ;) just that its not too hard to do if you want to put in the time. The dash took me about 2 days work so i can see why you'd want to do get somebody else to do it if you didn't have the time!
i took the dash out and tried to get the air cond fan working onthe weekend, and i put the turbo timer in, but connected a wrong wire at the key harness, so I ahve to fix that this weekend, just have the timer off till then. the steering wheel was the hardest to realign, took about 20 minutes to get the wheel on perfect. gotta get a plastic horn bit as the one in mine was broken and need a horn.
went to all jap at virgina, $20 for the plastic bit wher ethe door opener is. and thats second hand. just the plastic not the lever. nad its worn a bit.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
