Hehe.. it sounds like it's going to be a skyrice australia meeting at Gavin's next week.
My cars down their the whole week (because I can't do down during the week and my b/f can't get time off) so Sinbad (car) is having a sleep over at Aunty Manda's and Uncle Gavins :uh-huh:
  • Replies 181
well, i got my last service at the new nissan service depot at wooloongabba and i couldnt be happier with it
they were cheap, went way above and beyond (they greased every lock and hinge in the car, i aint never seen that done before)
did an awesome (4) wheel alignment and was still cheap as (as well as they let me know a few things i need to do next time (leaky gasket, missing bonnet rubber))
maybe they cant do all the hitech stuff gavin woods can, but screw driving all the way down the coast every 5000k
ill be back there for my next service for sure (props to woman for finding them)
yeah i was wondering why you added the last comment ;P
dont read qgl much anymore, mainly because its full of shit now and the flamewars dont exist anymore. The funs gone and the nazis reign.
I was going to ring today but rang outta time being sick. But I have to find someone taht can fix the air cond fan in the dash to work again it died and if I get this fmic shortly I would like someone to put it in, as I'm short of time. Mainly just want the odds and ends fixed and the car tuned up and service. I was planning on doing it at the same time,a nd getting it dyno'd and running smooth, just wondering if gavin would be able to do all this, or would I have too take my car to like 10 different car shops?
yeah i read your dash read me, its pretty easy to take apart, but the thing is I dont ahve much time these days. tadoy I wasnt felling 100% so I went out and got some cash and hunted around to see where i could get teh air cond fan checked and working. The turbo timer is just I have weird the wires to the wrong one, optput 2 is on the igition and not the other wire. fix weekend.
intercooler and piping shouldnt be too hard just need grinder, drill and a coping saw/jigsaw. but first have to see what piping i get with the kit. the bar and lights are easy to take off, but its a pirck to get the bar back on.
I restored a hj ute from 3 write offs,a nd painted it, so I do know a bit about handy work. Learnt most of it as a kid at dads work. Just atm Its cheaper for me to get someone else to do it while I earn the dosh, and if its all put together and serviced then tuned and dyno'd I get a car thats got the works done in one go. None of this every weekend drop off and check crap or get it serviced then next week tuned.
Time is the main issue I have, its a problem to get stuff done when 14 hrs of the day your at work, and 12 on the weekends. just been lucky lately to be able to have sundays off beacuse the dollar is up and not much coming tinto australia atm.
yup, time is money.. i wasn't really implying you were lazy ;) just that its not too hard to do if you want to put in the time. The dash took me about 2 days work so i can see why you'd want to do get somebody else to do it if you didn't have the time!
i took the dash out and tried to get the air cond fan working onthe weekend, and i put the turbo timer in, but connected a wrong wire at the key harness, so I ahve to fix that this weekend, just have the timer off till then. the steering wheel was the hardest to realign, took about 20 minutes to get the wheel on perfect. gotta get a plastic horn bit as the one in mine was broken and need a horn.
went to all jap at virgina, $20 for the plastic bit wher ethe door opener is. and thats second hand. just the plastic not the lever. nad its worn a bit.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
