Hi Guys, i wanted to buy this Skyline GT-t R34 but i don't know if it's worth the prices coz i don't really know how much is in the market so please help me out, i'll describe it to you guys, here we go : Nissan Skyline R34 GT-t late 98 Manual, 6 cylinder Turbo, Black, 54000kms, Nismo body kits, GREDDY Trust front mount intercooler, Blitz BOV, Blitz boost controller SBC ID2 , Kenwood VCD TV with TV Turner, Blitz air filter, Blitz turbo timer, Blitz Gauge, Momo Steering wheels, Flash Point Alarm, Turbo Back Exhaust, 6 months rego and selling for $34,000.... it has backfire and then a little bit smoke came out but when the car is park and put on neutral i revs up and have no smoke, is it okay or there is something wrong? please give me your advice if this price is good for this car and it looks really much like the photo i attached.......many thanx.....
HI Tommy,
That price is pretty decent for a R34 GT-T and it has quite a few aftermarket items, maybe you should take it in for a service and get the misfires sorted out ?
Where does the smoke come out ? the exhaust ? the engine ?
this is a really good price!
black smoke coming out of an exhaust is not normal, its overfueling. with my stock ecu in my 34gtt i never had black smoke coming out of it on wide open throttle.
accident damage. hrm..its very rare to find a car (especially an import) without accident damage.
sure its nice to have a car that hasn't been in one, but as long as the chassis is straight, panels can always be fixed/replaced. you should be worrying about the quality of the repair more than anything.
yeah got a skyline inspected, had a look at it. looked fine to me but they came up with heaps of stuff. theyre really thorough and they give you their opinion about the car. they told me that it wasnt worth buying the car.
probably saved me heaps in the long run.
Take it to an a mechanic who mainly does performance cars and imports. Tell him you are interested in buying an r34 and your intentions are to take the vehicle to him for servicing/performance mods.. and could he kindly check that it doesnt have anything wrong with it.
He may do the service for close to nothing to bag you as a future customer.
Thats probably the best piece of advice ever... well done mate :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
