Hi
Wanting to upgrade fuel pump in my R33 GTR, I want something that sits in the factory position and clips in like the stock fuel pump does
Besides the Japanese pumps, TOMEI, NISMO, SARD etc which are like $400 + is there any other pump that can use the standard mounting bracket, in maybe a BOSCH model?
Don't mind if it has to be modified 'slightly' as long as it sits as the factory fuel pump does and flows like a NISMO/TOMEI etc
Any help would be appreciated
Thanks
https://www.sau.com.au/forums/topic/246782-r33-gtr-fuel-pump-upgrade/
the japanese pumps, nismo, tomei etc are well worth the money. in both of my heavily modified GTRs I used japanese pumps and couldn't be happier. they fit straight in in about 10mins. sure you can hack up your cradle to fit a bosch pump, but the number of times I've seen people fit an aftermarket pump to the stock cradle and then get fuel surge due to improper mounting is insane. considering how important good fuel supply is I would spend the extra few bucks and get a nismo one.
out of the japanese fuel pumps, which do you beleive is the best choice?
they are all much of a muchness. i've used nismo and tomei and hks. if I had to buy one now, I think i like nismo the best. dunno why, I just have an image of them being slightly nicer quality. but in reality there is bugger all between them.
Probably the best thing about Nismo is that 99.9% of the time is going to fit perfectly.
well i just fitted a gen. walbro fuel pump..rated at 550hp..
its like half the size of my stock fuel...
it was the BEST fit...and i didnt think it would..but wen i saw the pump..i was lik wow!...lol
which is way smaller than an bosch 040!!!!!
but i drive a gtst...
But i was gona buy a tomei one..its lik an extra 100ish bucks...
but its really up too u..
it fix a lot of flat spots after installed too.. :P
Thanks for that Adam
Anyone put a BOSCH 044 into an R33 GTR tank?
I put one in a 32 GTR tank; I don't know how different they are internally to the 33 tank.
I wrote a tutorial on it and someone was kind enough to take photos, you'll find it in the DIY section
It may be of some help, I don't know.
In a 32:
* It is not a drop-in replacement (cutting/fabrication/adapters needed, but the work is pretty simple).
* It is as quiet as the standard pump was.
* It flows more than enough fuel at ~65psi (something that walbros seem to struggle with).
If you can verify that your aftermarket pump of choice:
* flows enough fuel at the target pressure
* is a drop-in replacement
I'd go down that path. Drop-in replacements are always that much easier to deal with and you can always go back to standard anytime you want to.
Regards,
Saliya
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
