  • Replies 148
My MR2 has just developed a leak in the targa roof so if I don't fix it before tonight (just needs some silicon) I'll have to bring my other car... the commodore VN :thumbsup: Sorry guys :)
Looking forward to it. I'm eating a small lunch now then starving myself until tonight! Gonna get my moneys worth :banana:
Kris, gimme a call later and let me know what time you wanna meet up.
No probs mate
doesnt matter what car you bring to meets / cruises.... we dont really care. The people make a event NOT the cars
AP is just saying that because he wants more people to come so that there is more duckage. He will make you order duck and he steals it off your plate. Be warned
shhhhhhh!!!
hey give me a buzz, before you go to the meet
shhhhhhh!!!
No probs man, I finish work at 9 so ill call u after that, should be there at 9:30 give or take 10 mins. You guys should still be there anyways.
Sif starve yourself
I'm about to have lunch #2
Yeah but dude I weigh like 20kg :) Gotta make room for this duck tonight. It better be as good as I'm expecting!
Oi Kris I'm bringing one of the chicks tonight :) Only met her once when I was drunk though so I can't remember if she's hot or not :P She txted me saying she wants to "get to know me better" tonight so I invited her along.
Yes, I am going to pull an "eMsta" might not be able to make it tonight
u live like 2mins down from the meetup
sif not at least show ur face
rain, hail or shine ill still be there
Yeah dude, you better be there!
You're one of the only people that I actually know. I need someone to talk to when I'm there aside from Kris! :)
If you don't come tonight then I'm not taking you clubbing like I said I would... :)
:P
Edited by jezza boii
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
