mine is at 1pm....hehe i will get there a bit earlier as well so might be able to catchup with ya mate
goodluck to both of us aye ;)
yea, ill probably see ya there... usually they are running pretty late so i should still be there at 1
and yea good luck mate, lol... i'll need it... i've never passed regency first time before... even if everything is fine they always manage to find something like a tiny leak somewhere... :(
Edited by Rocky88
+1
Once the initial raping has been carried out; If you have a list the next time you go there they will only check whats on the list.
A good question for officer Neil.
A bit like when I filed for divorce. The Magistrates Court kept sending the application back with minor edits all the time. Even made an appointment, went in and sat down with one of the admin people. Sure enough, a week later my application turned up in the mail yet again for more amendments. Grrr. They had to find one item at a time. 9 months (since the initial lodgement), 2 adjourned hearings, and more than 8 submissions later ... I'm finally divorced.
Reasons for returned divorce application ranged from:
- mispelt surname (which it wasn't, I know how to spell my own surname idiots)
- witness signature not identified as meeting requirements (it was a Proclaimed Police Officer idiots)
- affidavit of notice served not correctly filled (it was according to their first instructions)
- application missing pages, must resubmit with missing pages (pages 5 and 6 were removed by them because the ex and I had no kids to declare) Duh!
- affidavit of notice served in person not correctly served (did not serve to ex-wife - she authorised it to be served to a third party idiots)
- cheque for fee not enclosed (umm, yes it was, try again!)
- affidavit of notice served via mail (one tiny little boxed was not ticked - could have advised me earlier)
There must be some real bright sparks working in the Courts :)
Fail.
Edited by RubyRS4
i got done for tyres. all 4 had worn the inside edge out unknowingly!?!?! plus they were borrowed tyres while mine get re-rolled. the cops were at strath this morning(big set up like 5-10 bikes, had a r33 pulled over on the opposite side and were pulling everyone over inc bikes). they were good, open and honest. not attitude at all. told me things to make sure i check before i in for my inspection.
4 years and first actual run in with them.
Update, got it cleared yesturday night after work. so tis all good again
Booked my revisit for Thursday at 3:40. Gonna take it to the cop shop so I can atleast drive it. If I go down there with a hi-flow cat and its loud, will they defect me for it? Or will they just put it on the hoist and check off the stuff I failed for the first time? This baffle plate cannot be good for this car, its so slow the turbo barely spools.
go to your local hardware store Rok and get a 4mm T piece
lol the car is all good to go tomorrow...hopefully it passes first time
how did u go m8? ...i failed  :D
ride height was apparently too low even tho its stock and i passed with exactly same suspension setup 2 months ago... then apparently blue globes are illegal - wtf... and a little piece of rubber that goes onto engine mount had a small crack on it...
i know i shouldnt, but i lost my temper and told the guy that it all bs... he also wanted to defect me for not having all 4 screws in my front number plate, but i got so pissed off at him that he asked for second opinion and eventually let it go...
i swear regency is fkn tough now...
sorry mate, didnt have much time to talk to u there... i was late coz i got locked in my own backyard lol
Edited by Rocky88
Yeah, they are getting really really picky. I think everyone should really try to avoid having over the top mods on their car, Regency has just gotten that bit more stricter resulting in $1,000's to just get the car there only to fail it again.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
