Hi ive been having this issue for a month know i did all the normal stuff like new fuel pump, coils, new crank angle sensor, afm so on but hasnt solved my problem if any one has any idea on what to do next please let me know as i can not drive the car its really annoying. :)
https://www.sau.com.au/forums/topic/247206-r33-dying-randomly-while-driving/
You can do an ECU diagnostic using a paper clip and shorting out two pins on the consult port, a code will flash on the dash. Do a search for it on the forums, the ECU will supposedly remember problems for 50 or so starts. May help shed some light...
Edited by MintR33
Does the car idle roughly or abnormally?
i got that problem fixed it did idle rough got a new crank angle sensor and went away just dyes randomly know say ur driving and out of no where will loose all power and stop
does it idle when you slow down, after applying a tiny amount of boost. i've been having this problem as well. we figured out that the car stalls when you apply boost, even if its a little bit and then you come to a stop or change gears. i think its sumthing to do with the turbo , but then again i mite be wrong
i hope its not the turbo cars gonna send me broke lol :)
I would say it's an electrical problem, possibly one of the relays controlling the injectors or coilpacks. Maybe check the plugs (onto the relays) first, then try replacing the relays.
Sounds like your ignitor if its a series one (being that year it should be) which is located in the engine bay, S2 is actually bundled in with the ECU inside the car to avoid this problem. As it warms up (and its on its way out it) it should cut power to the coilpacks. Once its cooled (or using a cool shorting trick) it should start again. Replace or reposition it away from the engine to fix. Common on RB30's with the ignition module under the dizzy
Hey mate, I just collected my car from the workshop. I was having the same problem as you. I just did my 100k service..the mechanics told me the timing of my car was abit off which was causing the dying of the car and i had a boost controller installed which tuned my turbo. My car is driving fine now.. maybe you should check the timing.
Cheers!
Cheers!
Thanks man ye i got all that checked all turned out good engine runs like a dream my tuner is saying it can be your alarm kicking in when you are driving which imobilises the engine and shuts offf all i gotta say
SKYLINE OWNER SHIP= STRESS and ALOT OF FUN
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
