Hey guys
some of you saw my car at the meetup, just posting a few pics of the new rims on the car
19 x 9.5 +17 - 265/30/19 Dunlop SP Sport Maxx
19 x 10.5 +17 - 295/30/19 Michelin Pilot Sport 2
imo the right size 19" rim doesnt actually look small on the v35.
i also have Nagisa Auto Rear Camber, Rear Toe, and Front Camber arms in order to make the rims fit.
Running -2.5 Degrees Camber all round.
I also installed some HKS Kansai sway bars too. They make a MASSIVE difference to the body roll and handling of the car. A must have first mod for Everyone!
Car has been lowered, it is sitting on TEIN Comfort Sport Coilovers. I think they are at the max it can go in terms of height adjustment. This made the biggest difference to the look of the car, as a low V35 looks AWESOME!
one thing i planned for, is that i currently have 10mm hubcentric slip on spacers on order, so that i can bring the front rims out, bringing the offset of the front to +7. I would of ordered them in +7, but RAYS dont make them in that offset. Its +17 then +4...... big jump.
only 2 pics i have. enjoy.
-mark
Edited by BLISTC
https://www.sau.com.au/forums/topic/247485-new-shoes/
Is -2.5 degree a bit too much for daily driving ? I had my R33 previously set to around this, as I took it to track once in a while, and it wears out the inside half of the tyres real fast... as it's driven more on the street basically daily.
https://www.sau.com.au/forums/topic/247485-new-shoes/#findComment-4298239
hey guys thanks for the replies.
ive seen some V35's with 20" and in some photos it just looks too big. i reckon the best fitment would be 20" Rear and 19" front but then i dont know what that would look like.
-2.5 degree camber is alot, but all i do is going to get the tyres swapped around every 10,000kms or so, so that they will wear a bit more evenly. making the car look good comes at a price unfortunately.
PS. i also had to roll the rear guards as well to get that offset rim under the car
Edited by BLISTC
https://www.sau.com.au/forums/topic/247485-new-shoes/#findComment-4298638
Good work, looks nice and I hope you don't forget to switch the tyres with the Camber your running...
some people forget unfortunately wasting tyres early in the piece.
nah i wont forget
its something i always keep an eye on and do and have done with my last 2 cars also
https://www.sau.com.au/forums/topic/247485-new-shoes/#findComment-4300623
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
