ok so i have a gtst with 265rwkw, all the usual supporting mods, an unknown clutch (wont know till i blow it i spose) and a nismo 1.5way diff.
how risky is it for me to be flatshifting on:
a) street tyres (245/40/18 RE001's) on the street ( theoretically of course :) )
b) semi's
c) the strip
thanx :D
https://www.sau.com.au/forums/topic/247587-flatshifting/
Flatshifting from 1st-2nd and 3rd-4th no problem. Hard part is across the gate like 2nd-3rd.
If you get this wrong on a car with good power, say bye bye to your box.
I have to pause between 2nd and 3rd for a second or a ,orrible sound of syncro,s griding is what i get, ive tryed double clutching which only works sometime, and ive got a newish excedy single plate.
Read in HPI somewhere you can grind of every second syncro for a smoother shift but that sounds a bit bush mechanics for me.
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4298915
Double clutch=Example-if im in 2nd and want to go to third I, 1. depress clutch and select neutral, 2. release clutch, 3. depress clutch and select 3rd, 5. release clutch.(it sounds tricky but is easy as with a bit of practice)
Flat shift= Example-if your in second when you change to third you dont release the accelerator you just punch the clutch in throw it in third and release the clutch (and hold on because your about to loose traction)
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299043
Hmm....
The only times i would flat shift is if i know i'm going to spin the wheels. ie 1st to 2nd.
i think your car would spin 2nd to 3rd.
dont flat shift if its going to grip, thats asking for trouble.
i change pretty quickly when i'm giving it some... and even without flatshifting i tend to chirp 2nd 3rd and 4th
the car will spin 1st to 4th no worries if i flatshift....
so maybe on the strip with warm tyres its not a great idea?
just curious as the nismo diff is going in very soon and the car will be seein the strip for the first time and i dont wanna be trailoring it home
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299222
mlr, double-clutch is used for down changes, not up changes. It is designed to match the speed of the engine to the speed of the gearbox. Between steps 2 and 3 (while clutch is engaged, but gearbox in neutral), you would also give a blip on the throttle to bring the engine revs up over what they were when you commenced the down change, so the the engine is revving fast enough to match the road speed. In most modern cars with healthy synchromeshes, it is not actually necessary to release and re-engage the clutch in the middle part (steps 2 & 3 - what happened to 4?), but simply "blip" the throttle. This is commonly referred to as "heel-toe".
Hamish, if you enjoy bouncing the engine on the rev limiter on every (up) gear change, then by all means go ahead and flat shift. Unless you have the supporting electronics, I would strongly advise against the practice.
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299244
Step 4 was me swearing at the car.
Double clutching helps me between 2nd and 3rd, this i know for a fact. If i dont double when im up it it grids, if i double it generaly doesnt.
My box has about 170k on it so the syncros are sure to be worn.
You dont need to blip it going up gears only down, to match engine speed to road speed.
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299364
The point I was trying to make is that you have to do a judgement call on LOAD.
When you drop the clutch and spin the wheels, there is significantly less load on the flywheel>clutch>gearbox>drveshaft>diff>half shafts...... then there would be if you did the same thing, but the wheels GRIPPED.
When you chirp gears, thats different to flat shifting. You're typically not transferring 100% torque through the driveline. (50% throttle or so)
heck, even some high HP cars will always chirp no matter how soft you shift =D
and of course, all of these techniques transfer more load then smoothe shifting.
judgement call at the time, get a better understanding of what your actually doing with these shifts, and you wont need to rely on forum opinions to tell you if what you are doing is safe.
Personally, at the 1/4mile, when your going for a good time, you want to chirp as many gears as you can, without spinning the wheels. But just know you are stressing the driveline. But you cant get a good time without doing so. it is a test of your car's capabilities after all...
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299378
you mean from just smashing the limiter?
Ignition cut rev limiters are baaaaaaaaaaaaaaad.
Perhaps your pressure plate is knackered?
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299386
Na pressure plate was replaced w/ clutch and was doing it before they were replaced.
Back on topic, ive broken axles, driveshafts and a shifter once when i got a bit carried away once but that was in my old LJ torana.
https://www.sau.com.au/forums/topic/247587-flatshifting/#findComment-4299414
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
