i put a new exedy Sports Organic Clutch Kit two weeks ago i could smell the clutch a bit ive done 600ks on it now and i gave it a bit today in third gear,i dumped it and the clutch slipped like crazy,now my last clutch a exedy hd never did that but i stuffed the pressure plate in it and opted for the next one up that was recommended by crd for my power level.
my nismo lighten flywheel was done.
clutch is new
wtf is wrong.
the old clutch failed for no reason the cluctch was burnt on both sides down low the peddle pressure died every time you took off a bit hard and when it cold it was back.
this clutch feels like its very high in the peddle ,the peddle was adjusted but it still high in the peddle.
no leaks in the system no loss of oil.
can anyone help ill put some pics up of the old clutch
this is the pic of my new clutch
https://www.sau.com.au/forums/topic/247601-yet-more-clutch-problems/
maybe adjust the pedal so it disengauges a bit later so middle of pedal stroke, maybe as its near the top it still has force on the pressure plate so its not clamping right, or from what ive been reading around, a few of the exedy kits you get come with a non-exedy pressure plate if that makes sense and some people have been having lots of troubles with it slipping, as ive bought a 5puk clutch (exedy) it didnt come with the exedy pressure plate, just some random silver 1, so fingers crossed my clutch doesnt slip otherwise i will be pissed,
JV
JV
its a exedy pressure plate 100%
that's interesting cos I just had a HKS twin GD Max put in and the engagement point is right up the top of the pedal travel as well.....
is this usual for a twin?
from what ive been told yes it should be middle .
today i cracked the nipple for 5 sec on the the slave cylinder and the pedal is now in the middle,i am pretty sure the clutch will not slip now cos there must have been some pressure and i have relieved it now ...
Edited by WARLORD
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
