  • Replies 719
I'm using it as an excuse to justify replacing the standard swaybars with adjustable Whiteline bars.
It only hits when you've got it all loaded up in the middle of a corner and you hit a decent bump. I'm hoping the sway bars will increase roll resistance enough to stop it happening. Doesn't happen at QR or on the road, just those 2 spots at Lakeside - both have decent bumps in them when the car is all loaded up on that side.
If that doesn't work I'll look at other options. but I don't fancy relocating the loom...
well except then you either rub through loom, or fit plate and rub through tyre.
best bet is relocate the loom.
LOL
I have been a victim in my 32 at the circuit. ;)
learnt lesson, relocated now!
im looking forward to this. out of curiosity, for those who have done both winton and oran park can you put up your times. basic theory is that winton is the closest thing to oran park we have down here and could be a rough indicator of times to be had..
Handbags belts out 36s at Winton and 17s at Oran Park. But his car is not exactly easy to use as a yard stick because the thing is such a wild thing to drive. So may be worthwhile considering a GT Production STI used to run 1:33 at Winton and at OP they run 1:16
email nathan@superlap Bryce he'll be able to help with that.
it's going to be a ripper. hell I may even make a fool of myself in a car that's way above my skill level... :P
Enter the Truck Beer Man!!!
lol, it's pace is on par with my skill level. still it might give that RX7 a shake up as he comes up pit lane the wrong way at me...
Ha,,Ha,, thats as funny as Baron,,,thats a car I was asked to drive. I can't see it happening now as we are about to have a little professional argument soon.
If I do still get to drive it,,,there will be none of those shenanigans,,,so you might have to not use the truck my good man.
Merry Christmas everybody.
Love as always
Neil.
Neil you mean it's wrong to drive the wrong way up pitlane? But I seen a well known tv personality/instructor do it last weekend in his ute so it must be ok....
No Ben nothings wrong till you get caught. You should know that!!!.
No I would never drive the right way on my mobile,,,then reverse back into my garage and then reverse down pit lane again. Did i get that right???.
Enjoy Christmas everybody
Neil.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
