  • Replies 47
Originally posted by Milk
feel like been insulted
yep i do go around taking pplz cars
and that car park happens to be my bf's apartments carpark
those cars just parked next to it... something wrong with that?
nah nothing wrong with it at all i say....
try not getting your thumb in the next picture though :bahaha:
