i just "tried" to install the turbo controller from ebay and when i was running the car to find how to have the controler so it would run at 10 pound but the guage kept hitting something like 20 pound. :blink: i kept trying to change it but it wouldn't go down and now when i run the car and open the throttle all the way smoke comes out the exhaust and it doesn't sound like the turbo is spinning....wat do u think it is?...also wat can i do?
https://www.sau.com.au/forums/topic/247993-i-think-i-killed-my-turbo/
high chance of it being a turbo seal. get it checked out mate. doing a turbo swap is pretty easy (done it for a fair few SAU'ers so far) with the right tools/skill it shouldnt take more than 3-4hrs in and out.
u in sydney? do u know any1 that can check it out for me?
I'd like to know if you can f**k a turbo and not have it blow white smoke, as thats what my cars doing, no boost, bad metallic noises when it tries to boost.
turbo can do a few things on failure. you can blow a seal and have white smoke pour out, you can blow an oil seal ring and blow blue smoke out or it can seize up/break apart and have no smoke pour out.
yeah im in bankstown. send me a pm if you want me to check it out.
Well it appears mine is leaking oil (bottom of the turbos covered in oil), and the two times I tried to boost it (just after the nice big bang) I was getting metallic noises, all other vital signs were ok though. so I guess the turbos probably lunched itself, plus I was getting some light knocking sound from the head when I had it idling, this arvo. Best thing to do is a compression test?
ok well...there is smoke when i am moving and when the boost tries to kick in and there is that metalic sound... i live in bass hill
best thing would be to get it towed to a mechanic and get him to do compression/leakdown and oil pressure test.
yeah dude sounds like turbo is gone.
i didn't get a bang though and i can't see any oil at the moment.
thanks for the assist :blink: as f**ked up as it is trying not to let this get me down
for $250 for a 2nd hand turbo you can do it all yourself if you have the confidence.
it sounds like your turbo bud. it could be something else but thats my take on what you've reported.
can any1 help me out with a stock R33 turbo for cheap?...i don't have much money at the moment due to debts so if any1 can help me out and we come to an arrangement or something...i am only a 1st year sparky apprentice so i get paid peanuts :)
you saved $150 getting the boost controller fitted at your local dyno shop.
so it cannot all be that bad, remember when you put your new turbo on you will need to get the controler fitted by a professional so your new turbo does not break as well :P
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
