Hey guys I have some parts left from my R34 GTR which I sold a little while ago.
- Nismo coilovers $650
Set of 4 (2xFront and 2xRear) Genuine Nismo coilover suspension, adjustable in height and rebound I think.
They are used but in very good condition and still in their original box.
- Front V-spec diffuser $300
Original Front V-sec diffuser (additional lip) that is used and has scuff marks, good condition
The parts are in Melbourne.
I will post pics shortly.
You can pm me or call me on 0404 235 087
Cheers.
Arnie
Edited by GTstaR
Cheers.
Arnie
hi mate i will call you tomorrow for diffuser thanks , can you put pics up please
bleeds......, thanks for info ashneel
lol no worries man. if you can manage to fit the GTR lip onto you front bar first then the deffuser will fit. but if you dont mind playing around with the lip with a little chop here and there it might fit but will look weired
orh i was asking about the suspension not the lip/diffuser... anyone know?
Hey guys the diffuser is now sold, thanks for all the interest (there was a lot) :P .
The coilovers / shocks are still up for sale. I have had shipping quoted on them to Sydney.
It will cost $64 to get them to a sydeny depot which is in BANKSMEADOW NSW 2019.
It will cost an additional $18 to get them delivered to someones place in suburban sydney.
So if anyone wants them is Sydney I am willing to have them sent to the depot for $700 in total.
Cheers.
  • 1 month later...
The coilovers are still for sale guys.
$600 for pickup in Melb, $650 to a depot in Sydney.
I cant stress how cheap they are now, anyone with an R34 GTR would be crazy to miss an opportunity like this!!!
silly question but does anyyone know if they would fit an r32gtr
if so i want them.........
Im not sure to be honest, best place to ask or do a search in would be one of the tech forums I think.
34 GTR coilovers will fit a 33 GTR no problems. that's a very cheap price for nismo suspension
lower lip aint cheap either.. not surprised someone snapped it up! :banana:
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
