has anyone got an exhaust to sell or lend out to pass noise and emissions test.
i just recieved a letter in the mail saying someone doped in my car for noise.
will a stock r32 exhaust pass.
i know my current exhaust wont pass it was 114db on 2500 backoff and they want to test it at 4800rpm
and must be under 90db.
pm me if you want my number if you have parts to help.
https://www.sau.com.au/forums/topic/248427-epa-tests-on-r32-gtst/
You dont need to go for a test, its a warning is it not?
Got one too .. Just wanted for loud exhaust n told to make it quieter.. Bought a new car and kept the skyline hidden for awhile.
Exhaust has a silencer in it .. Buy an Apexi Active silencer - opens on throttle closed on light throttle like a normal silencer.
  • 3 months later...
So if u get a letter from the EPA, does that mean u will have to get both the sound test and emission test?
I got done by highway patrol and he said i will need to pass a sound test, no emission test was mentioned.
I dont know wat to expect, havent got the letter yet.
Also with the pod, im told now by the cop that putting it in an enclosed box is also illegal unless engineered, but
previously another cop said its ok if enclosed. So which is it? So hard to get these things sorted when the cops contradict each other.
im not sure
but years ago, an enclosed box for the filter would be a pass...unless its changed and needs engineer cert...
yes cops can be wrong....if you think about it... most of the traffic cops are the shit kicker cadets whom has started off as a no-body
i think boxed is still illegal unless you got a engineers, unless it complies with noise restrictions. Dont they do a drive by test or someshit. correct me if im wrong.
As for exhaust i have a cat back i keep aswell for these situations. should pass last test measured 86db me thinks
  • 3 weeks later...
Just 1 more question. I finally got the letter, and it says i need to bring my car to 'DECC Approved Inspection Station
for a noise test and an inspection of the vehicle's emission control devices by a DECC Approved Mechanic'.
Does this inspection of 'emission control devices' mean they're just going to check is has a cat or am i getting emission test also?
Thanks in advance.
Thanks in advance.
Hey
whatever you do make sure you go to the cambeltown approved mechanice not the granville one hes a Bastard ..... hell just do a noise test and check the car for anything else , he will take take pictures and the DECC Will send you a letter saying if you have passed , so try and make it as stock looking as possible .....
Hey guys,
Well ive been to the cambelltown mechanic just then, and passed the noise test, but he said my fmic will need to be put back to stock side mount or i will have to do an emissions test.
Do u guys rekon i will pass with current fmic or should i just change it and take it back to the mechanic, who will take a pic and send it to EPA?
I have put the stock catback on with EPA approved cataylic converter. What a f**kin mess. haha
should pass unless theres something wrong with the car. mine passed no problems, the problem lies with booking it in time, when i went to book mine there was a 6 month waiting period but i happened to get lucky and someone cancelled while i was on the phone and they fit me in the next week. went to the one in botany.
Just do the Emissions test with the front mount on it so once its passed you can show the
paperwork to the EPA / Police if they hassle you in the future.
I had to take mine to Botany and left it exactly as it was (3 inch Zorst ,Front mount, Power FC etc) and they didnt care
less what was done to it they just ran it through
the cycle on the Dyno but said it failed in one Area and even suggested the cat must have been dead so i got a new cat
and it passed with ease.
As stated the biggest drama is getting the car booked in in time before the Defect runs out.
problem is as stated by the guy from the epa when i spoke to him, the emissions test does not cover you, a copa can still defect you if you dont have a engineers. i basically said to him then the emissions test doesnt mean shit. he said yes lol.
ye this all seems like bullshit, even with engineers certificate u can still be defected really. I got my emissions test booked for the 15th june, driving around with stock exhaust. fun, fun, haha
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
