Where are spark plugs in a R34 GT? my car is getting a service now and the dude called me back. He Said that they will have to rip apart the manifold and its going to be an extra $200 on top of the service? does this sound right?
Edited by DiNoBoNeS
https://www.sau.com.au/forums/topic/248942-plugs/
Obviously none of you have done the plugs on a R34 ?
I've done it, and because of the additional traction control butterfly it is indeed necessary to remove alot more than an equivalent R33 etc. Not sure I'd pay $200 extra, but definately takes more time.
Plugs are easy, just do it yourself, your time doesn't cost you anything right ? :(
https://www.sau.com.au/forums/topic/248942-plugs/#findComment-4318063
doing plugs on a r34 is a flamin mongrel you just cant slide out the spark plug cover compare to a r33 some much shit is in the way in order to do the plugs, like paul said the throttle body, and plus like hoses and other random shit
https://www.sau.com.au/forums/topic/248942-plugs/#findComment-4319054
no its just time not including plugs it spun me out i will love to know how to do this gear my self so i do not have to waste cash
To Change List
1. Air filter
2. Fuel Filter
3. Spark plugs
and i on the look out 4 new person 2 look after me car. Speed works closed down and i do not know where to take it now i want some one to tell me what it has in it (Coil pack and Spark plugs)
Edited by DiNoBoNeS
https://www.sau.com.au/forums/topic/248942-plugs/#findComment-4319488
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
