hey all, like a lot of others, im getting yellow on the back of my car, its easy enough to get off, but will it eventualy stain the back end with yellow? Or will it always just be on the surface and be cleanable. I need to know so I can decide weather to put my stock cat in or not. tyty
https://www.sau.com.au/forums/topic/249073-protection-against-exhaust-fumes/
Cop see's the yellow stain.. his gonna' leave a stain on the back of your trousers lols.
and a yellow sticker on your windscreen.
But i havent tried removing it off my mates car, he got sick of it and put the cat back on and got a new rear bar :D
MRXTCZ
the fine for no cat won't be immediate, it involves being defected first. Then the EPA will need to conduct an emissions test, which is long and expensive, so im sure before you get officially fined for having no cat, you will have put a stock one on.
would not run a modded car without a cat. not only does it give the yellow stain off to attract cops all the cop has to do is smell the ex gas and he will know u dont have a cat. its a completley different smell of unburnt fuel and un converted gases. smells like my R31 race engine. has no cat. u can get rid of the yellow stain by running c16 or something but i dont think having no cat is worth ten bucks a litre haha
if you give you car a good wax first then after that atlease give it a wash everyweek it will come of very easy. i get the same on my 34 and after every wash i hit the whole rear bar with quick detailer spray and just wipe it off. good as new.
if you do that weekly your car will be clean and the yellow patch wont be noticable
Exactly!
get some high quality "Paint Cleaner" not some abraisive crap that strips your paint, and give it a good clean. Should remove the stain. Then give it a good polish and seal with either a wax or a polymer sealer. This should then protect the paint from further staining.
Exactly!
^^^+1
ive also heard that the stain can be from the exhaust itself being too short. if u put some spacers in it and make it stick out a bit further then it shouldnt be a problem. all fumes are comin out further from car.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
