hey all, like a lot of others, im getting yellow on the back of my car, its easy enough to get off, but will it eventualy stain the back end with yellow? Or will it always just be on the surface and be cleanable. I need to know so I can decide weather to put my stock cat in or not. tyty
https://www.sau.com.au/forums/topic/249073-protection-against-exhaust-fumes/
Cop see's the yellow stain.. his gonna' leave a stain on the back of your trousers lols.
and a yellow sticker on your windscreen.
But i havent tried removing it off my mates car, he got sick of it and put the cat back on and got a new rear bar :D
MRXTCZ
the fine for no cat won't be immediate, it involves being defected first. Then the EPA will need to conduct an emissions test, which is long and expensive, so im sure before you get officially fined for having no cat, you will have put a stock one on.
would not run a modded car without a cat. not only does it give the yellow stain off to attract cops all the cop has to do is smell the ex gas and he will know u dont have a cat. its a completley different smell of unburnt fuel and un converted gases. smells like my R31 race engine. has no cat. u can get rid of the yellow stain by running c16 or something but i dont think having no cat is worth ten bucks a litre haha
if you give you car a good wax first then after that atlease give it a wash everyweek it will come of very easy. i get the same on my 34 and after every wash i hit the whole rear bar with quick detailer spray and just wipe it off. good as new.
if you do that weekly your car will be clean and the yellow patch wont be noticable
Exactly!
get some high quality "Paint Cleaner" not some abraisive crap that strips your paint, and give it a good clean. Should remove the stain. Then give it a good polish and seal with either a wax or a polymer sealer. This should then protect the paint from further staining.
Exactly!
^^^+1
ive also heard that the stain can be from the exhaust itself being too short. if u put some spacers in it and make it stick out a bit further then it shouldnt be a problem. all fumes are comin out further from car.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
