Hi,
Well I have just completed my new build topped off with a GTR gearbox, I retained the r32 gtst diff. I am trying to work out the speedo difference so I can set it in the RSM.
Using a gear calculator I worked this out:
----------1--------2--------3---------4-------5
10----1158-----693----469------360-----271
20----2315----1387----938------720-----542
30----3473----2080----1407----1080----812
40----4630----2773----1876----1441----1083
50----5788----3466----2345----1801----1354
60----6945----4160----2813----2161----1625
70-------------4853-----3282----2521----1896
80-------------5546----3751----2881----2167
90-------------6239----4220----3241----2437
100------------6933----4689----3601----2708
Does that sound correct the Speed = RPM?
Cheers
Cameron
Edited by murrayis
https://www.sau.com.au/forums/topic/249125-gtr-gearbox-in-r32-gtst/
Nope it doesnt, the GTST item is fairly long and the GTR sender is very short.
the GTR sender is mechanical and all hokked up just need to adjsut the speedo, I dont mind if the speedo is showing higher than the actual speed but would like it to be as close as possible if possible.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
