but thats the bit i dont get?? it pours fuel out the back like it's got a free fuel card...
just because its running rich doesnt mean its got enough fuel for the air you provide the engine at those boost levels
at 18psi on a gtr with a stock fuel system, something clearly over its capasity where it be injectors or fuel pump
put the boost to 15psi or somewhere it doesnt ping and take it to a dyno place to see whats going on
https://www.sau.com.au/forums/topic/249164-gtr-detonating/#findComment-4321611
ahhh, ok cool, yeah i got a shitty boost controller, so it tends to spike a bit, kinda gotta watch it myself
https://www.sau.com.au/forums/topic/249164-gtr-detonating/#findComment-4321624
oh btw what max's out first injectors or pump, injectors been replaced b4 i got the car, not sure if bigger tho, but you'd think if they were in their right mind they would have yeah?? unless cash was an issue...
https://www.sau.com.au/forums/topic/249164-gtr-detonating/#findComment-4321628
yeah coz of the dust ay?? its not running 18, just every now and than it spikes, i run it at 10 psi now days just to be sure, that way it only spikes to 15 pound, haha
yeah need to take it to a dyno or hoist to see wtf is going on
oh and is there any way a boost controller could be making to turbo's lag??? like not hitting 15 psi till 4.5-5k or so?? thats pretty late for stock turbo's isnt it?
yes i know, my car is doing some f**ked up shit!!
https://www.sau.com.au/forums/topic/249164-gtr-detonating/#findComment-4321846
start saving your money. If you continue to disrespect your rb26 like this your going to need a rebuild.
says the bloke who's pic is of him doing a burnout... haha
i dont run the thing on 18psi, im just saying there is something wrong with my boost controller and its starting to let it spike, thats why i've turned it back to 10 pound so if it does happen to spike, it's still safe.
going to look at it over chrissy break and watch my boost gage like a hawk in between.
https://www.sau.com.au/forums/topic/249164-gtr-detonating/#findComment-4322546
the difference between his and yours, is that his is already a forged motor and it has been tuned to suit all the modifications made to it.
yeah thats why im only running 10 pound atm.
so im looking for nismo fuel pump and till then just gonna drive it around on low boost, then look at getting bigger turbo's!! and see if i can blow my engine...
and i've seen plenty of 'built' engines blow from doing burnouts. but that ussually the drivers, to me thats showing real disrespect to your car... but each to there own, im sure there worse things, like running your car lean, haha
Edited by Dearlove
https://www.sau.com.au/forums/topic/249164-gtr-detonating/#findComment-4323049
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
